Help me identify Crane Cams LS1 dual valve spring
I bought a used set, of assembled LS6 heads with these valve springs. According to the seller, they are Crane Cams dual valve that are rate @ 0.650in of lift. Only problem is, I don't know anything else about them. I narrowed it down to two possible choices of what they are. Either part # 144833-16 or 144832-16. The only clue is that on one side of the valve spring is a yellow stripe and on the other is a blue stripe. Any ideas?
According to the Summit Racing Equipment listing, the 14833-16 has outside diameter of 1.237" while the 14832-16 has an outside diameter of 1.264'.
See also: http://www.cranecams.com/334-343.pdf at Page 343
Check the seat pressure if you can. I have the 832's and they are only 110 at 1.800" installed height. I ended up shimming mine .060" to get around 130 on the seat. I think my springs had some blue and yellow markings on them, but don't quote me on that as I haven't messed with them for a few years.
I want to know if I have either part # 144833-16 or 144832-16. Looking at these valve springs there is a yellow stripe on one side and a blue stripe on the other. Also I want to know if they would be fine running the Thunder Racing LS2 cheatr cam?
Cam Specs: 215 int/230 exh .629/.592 117 LSA
