what is a good cam for 243 heads ?
Old Dec 27, 2010 | 03:13 PM
jaysan's Avatar
Originally Posted by 98blueSScamaro
And you cant handle my slow M6 cam car
yeah your right , I only drive rocket ships .
Old Dec 27, 2010 | 03:17 PM
stoverz28's Avatar
Here is the thread i told you about man.
https://ls1tech.com/forums/dynamomet...k-results.html
The guys wife wanted it to drive like stock and was against a cam, besides the extra power she had no idea what was in it.
Old Dec 27, 2010 | 07:31 PM
kjmj's Avatar
:lurk
Old Dec 27, 2010 | 08:08 PM
garygnu's Avatar
the torquer cam will make 400rwhp,and the EPS cam will also.what intake and what size injector do you have?
Old Dec 27, 2010 | 08:18 PM
jaysan's Avatar
whatever stock is haha
jaysan's Avatar
Originally Posted by kjmj
:lurk
fail
Old Dec 27, 2010 | 10:16 PM
studderin's Avatar
any cam is gona run good with 243s and make more power over LS1 your heads, with no change in the way it would run. With the same cam anyway.
theirs not really a "bad" cam to run if you want to change to thous heads, so its kinda a stupid way to ask.
Old Dec 27, 2010 | 10:33 PM
studderin's Avatar
The little brother of the cam I run, makes 425whp/393whp and gone 10.6s 128's on stock 241 heads.
Did really well on 243s,.... 440whp. check this one out too. The streetsweeper HT
https://ls1tech.com/forums/dynamomet...0hp-409tq.html
Old Dec 27, 2010 | 11:43 PM
98blueSScamaro's Avatar
I always liked that cam alot. The Gto boys love them too with there 243's and 799's It really help's them heavy pig's move....
Old Dec 28, 2010 | 02:16 AM
buzb026's Avatar
Originally Posted by bene
I'm running stock 28# inj/fuel syst w/ EPS cam 222/226~.597/.598 int/exh lsa 113, stock 243 heads. My inj duty cycle was 80% above 6K rpm.
what numbers did you put down???
Old Dec 28, 2010 | 10:08 AM
01ssreda4's Avatar
Cam Motion
C33-790 LS Hydraulic Roller Camshaft; 228'/232', .612"/.612", 113'+4'; 2,200 to 6,200 RPM
Old Dec 28, 2010 | 01:32 PM
  #32
bene's Avatar
Trunion King
It was something retarded high 489 rwhp. The guy tuned my car also is the dyno owner/operator. He dynoed my car on 3rd gear.
Old Dec 29, 2010 | 09:23 AM
  #33
Fondle's Avatar
westtexasbuff made 440/406 with stock 243's, and a torquer v2 cam, on a stock ls6 intake
Old Dec 29, 2010 | 05:45 PM
  #34
jaysan's Avatar
yeah I saw that . I am thinking about that cam . What did you think about it ?
Old Dec 29, 2010 | 06:24 PM
  #35
Fondle's Avatar
i have the same cam and i love it, little weak in lower rpm with 3.42 gears . 3.73 would wake it up alot, but still plenty of power 3,200rpm+
Old Dec 30, 2010 | 12:14 AM
  #36
01ssreda4's Avatar
Thats not the norm numbers for that cam or set-up. You are gonna get the OPs hopes all up, only to be disappointed when he dynos.
Old Dec 30, 2010 | 12:18 AM
  #37
caseypryan's Avatar
Welcome to the internet
Old Dec 30, 2010 | 12:27 AM
  #38
RyanJM's Avatar
I run stock injectors with a TSP MS3 113LSA cam. I will need new injectors when I get the ported heads but for now the stocks are running fine. Although you may wanna get a new fuel pump. I have the Walbro 255 since my stock pump gave out at 75k miles, not sure if it's common but if your doing the cam may as well get that outta the way especially if you wanna upgrade the injectors later or port the heads.
Old Dec 30, 2010 | 12:52 AM
  #39
Fondle's Avatar
my car made 441/406 with the same exact setup on 2 different dynos, so no... these are legit number and nothing out of the norm, i have different heads (prc stage 2.5) but i people are making better numbers on ls6 heads for some reason
Old Dec 30, 2010 | 01:03 AM
  #40
01ssreda4's Avatar
Close to 450 WHP is NOT the norm for a V2 and stock 243s.
