Forged 347 for NA....waste?
Now if you do the forced induction properly.....
Applying the available power becomes your biggest problem.
One nice thing is that a even seriously speced blown motor has excellent street manners and it will have a far greater chance of passing emissions should that ever become an issue.
Another is you can run any fuel you want to with a simple boost adjustment and you can extract the extra performance that true race gas provides via this same adjustment.
A stout NA motor will always require premium and will not benefit as much running higher octane fuel. Changing from 93 to 116 on a boosted motor can be worth 250 hp (properly tuned for the 116 at a higher boost level).
In the long run it is hard to beat boost, especially if cost is a factor.
I would think that a reasonable turbo system should be able to be built for approx the same amount of money that tricking out a NA motor would cost.
Kurty85's motor sounds perfect for boost! On 93 at 8psi I'd expect 750+hp and on 116 at 18-20 psi more than 1000 HP.
This would tend to consume driveline componets and rear tires at a faster rate however.
I also believe that motor will run fine on 87 non-boosted (not that you should).
Properly built I would also expect 100K miles+ street use out of it at the 750 hp level.
Not boosting that motor would be a crime IMO.
Start out with a stroker built to the lowest compression that will meet your immediate goals. This may provide you with further options down the road if you HAVE to have more power.
