Forged 347 for NA....waste?
why not go with an LS2 or LS3 block and do a 402/418/427 type build?
they are aluminum blocks, and the cost of the block isnt that bad.
if youre going to have the block out, id want to get some more cubes in it for a pure N/A build.
you can do an LS2 402 very reasonably priced.
If it were me, I would give Fraser a call at AES racing. They have been advertising a 390ci motor in the forced induction setup that I would get. You can also get it in an ls2 block (aluminum) and it'd be a 385ci. I believe that setup was about $4000 plus shipping and any added options for the shortblock and that is very good considering the attention to detail and wealth of knowledge AES has about motors.
You said something about being the underdog with the 347.. that's cool and all if you were out racing this for money every weekend etc but if your going to do it you might as well go big and be happy or go home and wish you had more.
Hell some people push the stock pistons to 550-600rwhp with a good tune.
If you are staying 347 I see no need to a forged crank. You can put that money into something else like cylinder heads.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
You should take an inventory of what parts you currently have that are going to be reused and what kind of power/cubes they can realistically support in NA build. Don't guess on this, talk to a builder who knows. It might be come apparent that your current stuff won't really support 402+ cubes or maybe they will. My point being you could easily end up with a compromised situation or a be kicking your self for not going bigger if you don't plan it out.
Don't forget all the supporting mods for the swap and upgrades to take full advantage of the additional cubes. Why go for the cubes then handcuff yourself with woefully inadequate heads/cam/intake etc?
-LS2 covers/extension harnesses/sensors $300?
-Cylinder Head upgrade to support 402+ cubes? $2000+
-Intake/TB/Injector upgrade support 402+ cubes? $1800+
-Fuel system upgrade? $300+
-plus other unforseen supporting mods (how's that clutch and rear doing)?????
Camshaft/valvetrain/fasteners/gaskets etc. and tune are a wash as they would get upgraded no matter what.
So while the shortblock maybe a smallish step $$$ wise, the supporting cast of parts can be quite a good chunk of $$$$. If you are buying a new top end anyway, then definitely go for the cubes, but if you were planning to reuse a set of heads/intake etc then I'd figure what they can support and budget accordingly. Nothing would suck more than to get halfway into it and run out of cash and be stuck with a half built motor or a wicked short block and a compromised top end that is holding it back. Or even worse get it all built then realize that for another $500 you could have picked up 60 cubes and the power that goes with those 60 cubes.
It's a slippery slope and the cash can dissappear quick if you don't have a plan.
Good luck....
Good luck....
Say you go forged with stock crank because you can't afford a complete build on bigger cubes. You later decide to n2o your car and end up snapping your crank. It is not unheard of. Sure they are stout from factory, but interchanging pistons and rods just transfers that energy to your crank. How much is it going to cost to rebuild your motor after that? Less than just getting a forged crank and forgetting about it? Just something to think about man. Not trying to persuade one way or another. Just helping you get all of your choices out there on the table.
