Any advice for initial start up?
Old Dec 29, 2010 | 01:15 AM
dgman10's Avatar
Default Any advice for initial start up?
im just finishing up a rebuild of a 5.7 in a c5. i should have everything hooked up and ready to start in the next day or two. im just wanted to see if anyone has tips or advice for the initial start.
thanks in advance
Old Dec 29, 2010 | 02:19 AM
WK Statesman's Avatar
Just went through the same myself over the last week.
Assuming you have modifications to the engine (cam etc).
What i did was disconnected the coil wires (no spark getting to engine), cranked it over for around 15 seconds or so. Purely to get the oil pumping around only.
Straight after fired it up (literally) started on first kick let it run for 5 minutes.
Checked for leaks, temperature etc then shut it down.
Then trailered it to the dyno tune to get run it tuned etc, as i have a warm cam and extra comp etc.
I didnt want to run the risk of running it too long without having all the settings changed.
Should get the car back tomorrow with my results
Good luck
Jamie
Old Dec 29, 2010 | 08:49 PM
dgman10's Avatar
Thumbs up
sounds good feel free to let us know what the results are.
i was thinking if i would disconnect the fuel pump when i prime the oil pump there wouldnt be any gas pumping into the cylinders, im not shure if that wold be better or not.
the main mods are tsp cam, ls6 intake, and long tubes if that helps for any reason.
Old Dec 29, 2010 | 09:33 PM
wickedbluess's Avatar
very good advise. thats what i did when i did my h/c.
Old Dec 29, 2010 | 10:15 PM
slap(A)hoe's Avatar
you dont have to disconnect the fuel pump just pull the fuel pump relay out it want let the pump run with it out
Old Dec 29, 2010 | 11:13 PM
dgman10's Avatar
What fuse activates the fuel pump relay or where is the relay at.
Old Dec 30, 2010 | 12:24 AM
Quick and easy, to disconnect the 2 coil plugs on either side of the bank, takes less than 30 seconds, no guesswork
My tuner rang me today, is bedding in the rings etc, all is going well, should get my RWHP/KW tomorrow, less than 400HP/300KW i would be disappointed, but at the end of the day it is a number, it is how the car drivers that is important.
Remember when you have done the first hour or so, dump the oil and filter.
Let us know once you commence the run in process. Are you tuning it or running it in yourself?
Jamie
Old Dec 30, 2010 | 01:47 AM
dgman10's Avatar
Im planning on running it @ 1 -3k rpm for about 5 min after everything is primed,.ill let every one know tomartow pm
Old Dec 30, 2010 | 01:25 PM
slap(A)hoe's Avatar
fuel realy is right the in the fuse box on your drivers side look at the cover it will tell u which one is the fuel pump relay
Old Dec 30, 2010 | 01:52 PM
NC98Z's Avatar
Make sure you have a Fire Extinguisher handy. Fiberglass burns quick.
Old Jan 3, 2011 | 11:02 PM
dgman10's Avatar
Talking
alright this is for anyone who wants to know the steps i used. everything worked out great.
keep in mind that i had drained all fluids. i also reset the pcm prior to doing everything by pulling the two fuses for 30 secs and then putting them back in.
1. i put oil in the motor and a zinc additive that helps with engine breack in.
2. fill the coolant resevor the the mark
3. i pulled the two fuses that activate the fuel pump
4. crank the motor for 5 seconds to build oil pressure
5. plug the fuel pump fuses back in
6. start it. mine started right up i let it run for about 20 seconds and then turned it off to check for any leaks
7. start in up again and let it run untill it heats up and the thermostat activates (my c5 is just over 220 deg.)
8. while letting it run i was checking for leaks, watching oil presure and just making shure that everything was working right.
9.after the thermostat kicked in i had to added a little more coolant, i checked the oil to make shure it was clean. i started it and let run to see that the cooling system was working.
10.then i took er out for a spin.
