help
Old Jan 6, 2011 | 12:21 PM
z06kuwait's Avatar
Default help
hi guys
i have a problem
i have z06 model 2002 i installed a Trick Flow Package from summit.com
heads and Camshaft and i buy diamond Pistons -2 with rods
the heads is 215 , 64 cc .
the cam 228 ,230 , 585 ,585 lop 112
but in dyno 422 hp 377 torque
i dont see any power in the car
but it should give me in dyno 470 hp at least.
plz help guys
Old Jan 6, 2011 | 12:23 PM
Grimes's Avatar
Hum, more details...what are the other mods done to the car, and was the car tuned properly? Also, what type of dyno was used?
Old Jan 6, 2011 | 01:20 PM
z06kuwait's Avatar
i but kooks Headers with X-Pipe with Corsa exhausts , Vararam Air Intake , Crank Pulley slp , for the tune in the graf in 6.200 r p m its go dawn but now i dont see problem
in the graf its good .
normal dyno
Old Jan 6, 2011 | 01:54 PM
dudeiwin86's Avatar
so you put in -2cc pistons? wouldnt that lower your CR from the OEM flat tops?
why pistons at all? was the assembly rebalanced?
Old Jan 6, 2011 | 02:00 PM
NC98Z's Avatar
You should have milled the heads down to 59cc chambers, ran you a set of .040 cometics and got your compression up across the board. Take advantage of them -2cc piston reliefs.
Old Jan 6, 2011 | 02:03 PM
z06kuwait's Avatar
i but -2cc pistons for 250 nitrous
Old Jan 6, 2011 | 02:06 PM
z06kuwait's Avatar
but the heads and Camshaft suppose to give me performance
at least 470 hp like i say
Old Jan 6, 2011 | 02:09 PM
z06kuwait's Avatar
they told me in kuwait to change my cam
Old Jan 6, 2011 | 02:11 PM
z06kuwait's Avatar
should i change it ???????
Old Jan 6, 2011 | 04:54 PM
SOMbitch's Avatar
Mill the heads and run a bigger cam. I still don't see you making 470 though that would be a big jump.....
Old Jan 6, 2011 | 05:46 PM
garygnu's Avatar
the trick flow top end kit from summit is crank hp.what tranny?if a auto what stall?what is your air fuel ratio like?what injectors did you use?what was your timing?what was the air temp when it was dynoed?do a compression check ...and many more questions.
Old Jan 6, 2011 | 07:12 PM
fordkiller09's Avatar
i just got back from watching a hc car with underdrive pully and ls6 intake and longtubes put down 447 i think 470 is asking alot might be possible but i dont think with that cam
Old Jan 6, 2011 | 07:49 PM
SOMbitch's Avatar
Even with a bigger cam and more compression I don't see 50rwhp gain even if the tune is total ****........
