Cam sizes for everyday drivers
Old Feb 9, 2004 | 03:36 PM
NBM2001z28's Avatar
Restricted User
Default Cam sizes for everyday drivers
whats the biggest you can get away with single springs also. I dont really want to go to a double because of the added cost. Is there anything bigger then a 224/224 .581/.581 112 ls1?
Old Feb 9, 2004 | 03:45 PM
gomer's Avatar
I drive my TSP231/237 70miles round trip to work and back every day. I also ran it for 2 or 3 thousand miles on 918 springs. I'm sure there are loads of people out there daily driving cams as big or bigger than mine. I love my big cam and would never go back "small" again.
Old Feb 9, 2004 | 03:52 PM
99-LS1-SS's Avatar
STF Veteran
I have the 224/224, .581"/.581", 114 LSA and I drive it everyday with a 2800 stall converter. Texas Speed has a deal with the double springs and it isn't much more. I think single springs are fine but I want double incase something breaks. I like having the insurance of another spring. JMO
Old Feb 9, 2004 | 03:54 PM
93Polo's Avatar
FM11 (228/230) on a 112LSA driven daily here. Great cam
Old Feb 9, 2004 | 03:56 PM
NBM2001z28's Avatar
Restricted User
What springs are you running? are they doubles or singles?
Old Feb 9, 2004 | 03:57 PM
NBM2001z28's Avatar
Restricted User
What lifts are you guys running?
Old Feb 9, 2004 | 04:03 PM
gomer's Avatar
Now I'm running the Pariot stock diameter "gold" duals. I've had them for around 4,000 miles. Before them I ran the comp single 918's for about 3,000. The lift on my cam is .598/.595. The 918's are a good spring, but I like the "insurance" of the duals. Texas speed has them for under $300 with ti retainers and everything else you need.
Old Feb 9, 2004 | 04:09 PM
NBM2001z28's Avatar
Restricted User
what do you guys think of a 230/235 .595/.595 112 lsa? dual springs and titanium retainers with new push rods obviously
Old Feb 9, 2004 | 04:12 PM
gomer's Avatar
Some headers will be a requirement... along with a damn good tune. After that you could probably scare the crap out of yourself pretty easily.
Old Feb 9, 2004 | 05:09 PM
NBM2001z28's Avatar
Restricted User
well, i've thought about this for the longest time, basically i want a significant gain and i want to run 11's after headers tuning and the cam swap. so basically that means something bigger then a 224. im goin to wait till spring break and pick up the stuff. that means headers + cam swap, then a trip with the car on a trailor to speed inc. i dont feel like taking the chances of an overheating problem etc on the 1.5 hour drive.
Old Feb 9, 2004 | 05:16 PM
DD966's Avatar
1) You can achieve 11's with 224 cam
2) Don't they have emission testing in IL. ?? (They did when I lived there 5 years ago) Better make sure it'll pass emissions before slappin' a big cam in
Old Feb 9, 2004 | 05:55 PM
NBM2001z28's Avatar
Restricted User
Not where i live and i'm goin for 10's with stock heads and full bolt ons. I'm far from full bolt ons right now thats why with the cam/headers/tune i'd be happy with an 11.
Old Feb 9, 2004 | 06:02 PM
silverbullet00's Avatar
You may want to wait until Jason @ TSP gets through testing his new TRx cams, if you go to the dyno section look for the post that starts out with 440 something. Cam, headers and some minor bolts ons, putting down 440 at the wheels If that doesn't sound good I have a 224/581 on a 112, I would let go for 250 has 4000k on the cam
Old Feb 9, 2004 | 08:49 PM
NHRAFORMULA00's Avatar
__________________
not in every county in illinois like kankakee
Old Feb 9, 2004 | 09:15 PM
1bdbrd's Avatar
Exclamation
__________________
you live in the triple K? i have a buddy that moved down to missouri from there a couple years ago. dunno if you know him or not, his name is Mkie Vickers and he had a red 96 RS when he moved here...
Old Feb 9, 2004 | 09:50 PM
TTopJohn's Avatar
That should probably read Jason @ Thunder Racing
If you are going big, they are cooking up some interesting stuff at Thunder right now.
Old Feb 10, 2004 | 07:24 AM
NBM2001z28's Avatar
Restricted User
I've heard its like a 240/something or other and that's insane for a daily driven car. i really want to see the numbers though.
Old Feb 10, 2004 | 08:24 AM
99 Black Bird T/A's Avatar
If you go bigger than ~220, gears really help with making the car more fun to drive and easier to drive. Headers as mentioned above are very important for best results. Tuning helps alot with driveability and is critical the bigger the cam is.
If the car gets OBD-II scanned you can go bigger than 224 and pass with correct tune.
If the car gets sniffed a 224 XE-R on 113 or 114 LSA should pass sniffer with correct tune. Some folks have passed sniffer with ~230 sized cams on a 114 with a special emissons tune but I'm told it can get a little dicey.
The roller test I'm not familar with.
Old Feb 10, 2004 | 08:35 AM
JoSeY's Avatar
MTI X1 230/227 .591/.571 112 drove the car everywhere....no probs...no surging....great for stock heads and really shines with ported ones.
I ran duals just for saftey
Old Feb 11, 2004 | 07:16 AM
NBM2001z28's Avatar
Restricted User
No ****, you live that close? im in bourbonnais
__________________
