Valve Spring Maintenance
Old Jan 12, 2011 | 02:45 PM
Midnight02's Avatar
Default Valve Spring Maintenance
Hello All,
You guys have helped me with dialing in a build that's perfect for my needs -- for that I thank you. Just short of 575 rwhp on a 125 shot of N2O with great street manners and plenty of N/A power under the curve.
Now that my setup is complete and has been running smoothly for a couple years, I have a "maintenance" question.
Went with Comp Cams 928 springs with the relatively mild cam below (228/230 .585/.585, 112 LSA). I got a set of 918s in a kit I bought from TEA, however Vengeance made the decision to use 928s for the install citing the issues Comp Cams were having with 918 failures a couple years ago. For that I'm most grateful! The rating on the 928s are well in excess of the cam's max lift, however after a couple years (and 15,000 miles) of use and occassional abuse is it time to change them out?
How often should I look to change the springs? Anything else I should look to maintain while we're in there?
Thanks!
Old Jan 12, 2011 | 03:44 PM
slt200mph's Avatar
Those springs will last a whole lot longer than 15,000 miles on a cam that size. You can pull them and see what kind of spring pressure they still put out. But I would not worry about it at 15,000 miles. I ran a set of those on a cam with similar specs and replaced them at 45,000 miles and checked them and they were still good when I replaced them.
Old Jan 12, 2011 | 04:55 PM
JPH's Avatar
JPH
Originally Posted by Midnight02
Hello All,
Thanks!
It all relates to pressures and valvetrain issues. Pull a couple like slt200 said below and have them checked. Other things such as lifters, cam bearings or even rocker trunions might wearout first.
Old Jan 16, 2011 | 09:47 PM
Midnight02's Avatar
Thanks for the input guys. Sounds like I'm likely OK with the springs for a little while longer.
Old Jan 16, 2011 | 09:57 PM
Squirts11's Avatar
^Yep. Personally, I'd check spring pressure every few thousand miles. Cheap insurance. However, like said above, those spring should last a while with such mild lift.
Old Jan 17, 2011 | 01:30 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I made it 28k miles on a TR230 on 918's before I went to duals just for hopes of a larger cam. We checked about 6 of them and they were boarderline but I bet they would have gone a few thousand more miles. I would say you are good on the springs for now.
Old Jan 17, 2011 | 09:46 AM
BIG_MIKE2005's Avatar
I have been running my Patriot Gold Dual kit on my 224/.581 cam for about 60k miles
