LS7 lifter #
Old Jan 13, 2011 | 08:58 AM
LS1MUNN's Avatar
Default LS7 lifter #
Anybody know the part # for LS7 lifter? single lifter or set part 3?
Old Jan 13, 2011 | 09:00 AM
KevinR's Avatar
Old Jan 13, 2011 | 09:12 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Single = 17122490
Singles are pretty expensive though....if you're needing more than 3 or 4, it's less expensive to buy a full set!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 13, 2011 | 09:16 AM
LS1MUNN's Avatar
Thanks Guys!!
Old Jan 13, 2011 | 10:27 AM
LS1MUNN's Avatar
I only need 1 but I am going to buy the whole set. So I will have some singles for sale cheap if anybody needs one.
Old Jan 13, 2011 | 11:21 AM
KevinR's Avatar
You only need one because you have one that went bad in your setup? If so, what lifters are in it now? The reason I'm asking is because I believe they are a bit taller than stock lifters. If you are changing one out, you may want to go ahead and change all of them. Just my .02 cents
Old Jan 13, 2011 | 11:47 AM
LS1MUNN's Avatar
I currently have LS7 lifters with less than 300 miles on them, I have reason to believe 1 of them has failed. I have 1 that isnt pumping oil through it anyway. So Im going to replace only the 1.
Old Jan 23, 2011 | 11:32 AM
bamaballa205's Avatar
Intrested in getting one from you if you get the whole set.
