Harmonic Damper ARP Bolt?
Old Jan 14, 2011 | 02:08 PM
Paul 75 L82's Avatar
Default Harmonic Damper ARP Bolt?
I have the torque information if you use the GM torque to yield bolt for the harmonic balancer install, but I'm going to use the high price ARP bolt. What's the torque setting and procedure for the ARP bolt?
Old Jan 14, 2011 | 03:21 PM
JPH's Avatar
JPH
Drive it on with a 1/2" air impact gun and your good to go! You won't have any issues.
Old Jan 14, 2011 | 03:58 PM
vettenuts's Avatar
Using ARP Lube, I used 190 lb-ft but they may have since changed this value. Call ARP for the latest information.
Old Jan 14, 2011 | 05:56 PM
99Bluz28's Avatar
With a Fastener Tensile Strength of 190,000/200,000 PSI, and a Fastener Diameter of 16mm ,ARP lists it at 244 lb.ft., w/ARP lube.
Old Jan 14, 2011 | 11:37 PM
1SlowHoe's Avatar
Destroyer of Transmissions
All you need is an 8 foot breaker bar to tq it to spec
Old Jan 15, 2011 | 12:19 AM
99Bluz28's Avatar
I just make sure the front of the car is high enough so the TW handle doesn't hit the driveway, then I just use my legs for additional leverage. IMO, it's not very hard with a 2ft long Torque wrench.
Old Jan 15, 2011 | 12:24 AM
LilJayV10's Avatar
What the hell is wrong with you?
Old Jan 15, 2011 | 10:18 AM
JPH's Avatar
JPH
Not a thing. You try torquing that bolt down to 200ft lbs in the car.
Old Jan 15, 2011 | 08:17 PM
S10xGN's Avatar
Borrow a 600 ft/lb, 3/4" torque wrench and call it a day!
Old Jan 15, 2011 | 08:18 PM
Greekey's Avatar
Holy ********.
Old Jan 17, 2011 | 12:03 PM
Shockwave179's Avatar
Jesus that torque wrench is serious business...
Old Jan 17, 2011 | 06:17 PM
JPH's Avatar
JPH
My gosh Russ. I know what your saying, just a tad overkill.
Old Jan 17, 2011 | 07:42 PM
S10xGN's Avatar
It can be done by lots of methods, but the easiest is usually the best. Pulling this wrench to 240# is like arm wrestling a 6 year old!
Old Jan 17, 2011 | 08:22 PM
618HAWK's Avatar
Use that daily, to torque a Boeing 747 axle nut to 450 ft lb. And you thought 250ft lbs was alot. Can say it dose make things a bit easier for a balancer bolt.
Lots of leverage..
