ms3 cam head choice?????????
Old Jan 27, 2012 | 11:56 PM
SF 1HOTLS1's Avatar
Originally Posted by TurboStangJON
I've got PRC 2.5 5.3 heads and they seem to do pretty well. Car ran 11.01@123 last week with a small 3600 stall and that was at 3300 pounds. The car made 429 with the converter unlocked through a 12 Bolt with 4.10's. I could have spent more and went with a better head but I like them because they were cheap and effective.
was that with a qa1/afco/strange shock and a transbrake?
Old Jan 28, 2012 | 08:46 AM
TurboStangJON's Avatar
My 11.0 was with all stock suspension and a 4L60E with just a shift kit. The only aftermarket piece I had at the time was a torque arm so the rest was factory. Now I have Afco's all around with full suspension and it runs 10.20's@130 or 6.40's@106 in the 1/8th. That's off of the footbrake with the identical motor with no changes.
Old Jan 28, 2012 | 09:37 AM
BOBS99SS's Avatar
Captain Double Post
i hope you are getting a deal on the bbk intake, if your going to buy one new i would look for a used fast setup, not knocking the bbk intake at all though, also what i have found really helped my ms4 was the tsp duals , there is alot left in your setup , every lil thing i do helps, max effort cams need max effort parts
Old Jan 29, 2012 | 12:49 AM
Mazzenger's Avatar
I think you can't go wrong with either TSP / AFR or TFS heads based on what i have witnessed and experienced.
I had AFR 205's when I had the MS3.
Old Jan 29, 2012 | 01:17 AM
SF 1HOTLS1's Avatar
dam how did you do that? i have the same setup (ms3 cam. fast 92, yank 3600, 10 bolt 373s, with drag radials. just lca's, torque arm, panhard bar) and run 11.9 on motor and 11.4 on a 125 shot.
Old Jan 29, 2012 | 10:29 AM
What's your car 60'? Is it spinning? What kind of power did it make on the dyno? What's your race weight? When I went 11.0 on motor my best was a 1.51 60' and I think it would have done better with more converter. Now my car currently 60's in the mid 1.3's (1.35-1.37) with the 5000 stall. Before I did H/C/I I ran 11.2@123 on the stock untouched motor with 4.10's, 3600 stall, 125 shot, and longtubes (full weight no suspension). I consider the MS3 a max effort cam and like BOBS99SS said max effort cams need to be surrounded by max effort parts. A 3600 stall is small for that cam and I would have something in the 4000+ range. Take my car for instance, I took 250 pounds out, changed the converter/trans, and went through the entire suspension and gained .7 and 7MPH. Granted I did a lot of changes but none of that involved the engine.
Old Jan 29, 2012 | 01:09 PM
enigmah's Avatar
I have a set of ETP 215's on my WS6 with the MS3 with a 90/90 combo and my cars putting down 463/411 to the wheels.
