WOT hesitation...?
Old Feb 10, 2004 | 02:09 PM
v8maro's Avatar
Default WOT hesitation...?
I can feel a slight hesitation at diff points through the rpm band when at WOT, but the PCM doesnt register a missfire, and the o2's aren't throwing codes either. What could cause this? Would a car needing a tune have this problem? I had my car tuned without the LT's and ORP, so thats the only thing that changed. Any ideas? (btw, i didn't hear any pinging or detonation)
-Steve
Old Feb 10, 2004 | 02:12 PM
gomer's Avatar
-Steve
Mine was doing that occasionally and I installed a new set of plugs and cleared it right up.
Old Feb 10, 2004 | 02:44 PM
v8maro's Avatar
Ok, I was going to do that this weekend, I think i'm running really rich and thats causing it. The car sat for a bit so that could be it too.
-Steve
Old Feb 10, 2004 | 03:20 PM
Hannibal's Avatar
When you acclerate at WOT - does the car seem to bog then catch itself again? Like what I used to refer to as a "hiccup?"
Old Feb 10, 2004 | 03:24 PM
Debian Dog's Avatar
Yes if your running rich it will bog. How rich is rich?
Old Feb 10, 2004 | 03:37 PM
v8maro's Avatar
No, no hicup, it starts out fine, just in the middle of the rpm band it will feel like a miss, very slight too.
-Steve
Old Feb 10, 2004 | 08:39 PM
SSTYCOON's Avatar
-Steve
change your plugs and wires or check them., get aftermarket wires if you don't have them already.
Old Feb 10, 2004 | 08:49 PM
SuperSlowSSLS1's Avatar
Mine Is Doing The Exact Same Thing I Had It Tuned With The Heads/cam And Mac Headers
Changed To Flp's
And I Havent Gotten It Retuned Yet And Know It Likes To Jurk Very Bad Like Under 2500 Rpm And Then It Seems To Catch Its Self..
I Dont No Whats Wrong With It..
But Its Scarying Me Pretty Bad I Thanking That It Is Something Major..
And When Ever Iam On The Gas Like It Sounds The Exaust Is Like Puting Like Untill It Gets In To A High Rpm And Then It Seems Ok Lately When Ever I Drive The Car I Have To Keep It Above 2500 Rpm To Keep It From Doing What Its Doing..
What Could It Be?????????????????????
Old Feb 10, 2004 | 11:05 PM
Ferocity02's Avatar
Mine was doing that too, I changed the plugs and it seems to have gone away. Still might have it a little bit but hopefully dyno tuning will get rid of that...
Old Feb 11, 2004 | 12:54 AM
What Is It Caused By?? I Was Starting To Think That It Might Have Something To Do With My Fuel Pump Going Bad Or Something ??
What Was Ur Prob?
Old Feb 11, 2004 | 04:09 PM
So Replace Plugs And Get A Retune
