Pushrods question
Old Jan 20, 2011 | 08:37 AM
SLIVER-SS's Avatar
Default Pushrods question
Hello everyone
I know you will tell me check it with the pushrod checker tool but unfortunately I don’t have it and I can't get one.
Can I just use 7.350 pushrods just to be in the safe side??
The cam am getting is 231/234.617/595 and I will be installing stock 799 heads as well.
i might change to 228r but not sure yet.
thank you
Old Jan 20, 2011 | 09:37 AM
Jon@Texas-Speed's Avatar
Are the heads milled? What gasket? What lifters? Let me know and I can take a guess at it. Why can't you get a checker? That's the only way to know for sure.
Jon
Old Jan 20, 2011 | 09:50 AM
SLIVER-SS's Avatar
not milled, stock gasket and lifters
i cant get a cheker becasue where i live nobody has one and its going to take time to order one.
and i only have a few days to do the install.
many people here just use the 7.400 and hear a ticking sound when the car is cold and they are fine with it.
but me i cant live with the ticking sound
thank you Jon
Old Jan 20, 2011 | 10:31 AM
RARON455's Avatar
If your close North Richland Hills Texas I have one ill let you borrow,,, You really need to be sure on the length.
Old Jan 20, 2011 | 10:37 AM
SLIVER-SS's Avatar
Thank you Raron455
i live in the middle east
i could order one its only 19$ but i dont have the time to wait, shipping takes about a week maybe and sometime more
Old Jan 20, 2011 | 06:39 PM
PREDATOR-Z's Avatar
Looks like you need 7.425 p-rods
Old Jan 20, 2011 | 08:46 PM
SLIVER-SS's Avatar
aren't the 7.425 long ??
Old Jan 21, 2011 | 01:50 AM
chrisfrost's Avatar
Hello , how are things in the middle east ? The stock push-rods are 7.4" and a cam with higher than stock lift will have smaller than stock base circles for each of the 16 lobes , so longer push-rods for anything from .525 and higher lift Do You have the cam and do You have either a micrometer or a caliper graduated in thousandths of an inch ? If so , measure the base circle of 1 of the lobes (not the bearing journal) and if You also have the stock cam , measure base circle of 1 of the lobes and take 1/2 the difference . For instance if the new cam base circle is 1.85" and the stock cam base circle is say 2.05" , the overall difference is .020" but the difference on the valve-train will be .010" provided the heads, gasket ......are the same . If You don't have the stock cam to measure , go to the beginning of "Gen3 internal engine" and that info is in 1 of those yellow stickies or ask someone they will probably tell You . Good luck
Old Jan 21, 2011 | 01:38 PM
SLIVER-SS's Avatar
thank you soo much chrisfrost
and the middle east says HI im in Dubai, UAE
i will try to find me a stock cam and do what you said, if it dont work i will just order the checker and do it the right way
Old Jan 21, 2011 | 02:43 PM
Eng.LSX's Avatar
This is a custom specs camshaft right ?
Any dyno numbers or track numbers for it ?
I think 7.400 is ok for your setup .
Old Jan 21, 2011 | 03:01 PM
disc0monkey's Avatar
count the number of turns from 0 lash
1 turn is .047
Old Jan 21, 2011 | 03:20 PM
SLIVER-SS's Avatar
yes its custom
no dyno or track numbers
it was installed in a L98 6.0L Holden ... we have it as luminna ss from chevy,
many cars here make around 420 or 430 depend on the tune from cams close to these specs.
