Heads/Cam Swap - Steam Tube Question
Sounds like a dumb question, but seriously can't find it addressed anywhere.
I'm swapping heads/cam on a LS6, and obviously need to reuse the LS6 steam tubes. From what I found, depending on revision, the steam tubes either have a gasket or an o-ring.
Regardless of revision, where does one find either the gasket or o-rings? I can only find new steam tubes. I'd hate to swap the tubes over and suddenly have a coolant leak I didn't have before.
Part numbers would be great.
Thanks!
Thanks!
Try this - I am still looking for something more specific.
https://ls1tech.com/forums/general-m...t-numbers.html
Edit Supplement;
Coolant Plugs - 12602540
coolant Gaskets - 12551933
Front Coolant Pipe - 12602544
Edit Supplement;
