heads heads heads!
Edit: Sorry, I just realized that it put this in the wrong section >.<
If you plan on running boost I would go ahead and get the cam for that and have the heads worked or whatever you are planning. Don't get a trex just because it will "fit". You probably won't lose enough power to notice. The stock heads are 66.67cc and the 6.0 heads are 71.0cc.
If you're set on running N/A for a while, remember you'll have to pay for multiple dyno tunes eventually (been there...it's a pain in the ***/wallet). But I'd prob opt to run a big cam with stock heads vs. stock 6.0L heads. At least this way you'd keep some compression in the equation.
