Need Help On Cam For STS Turbo!!!!!
ive recently purchased a sts turbo kit with intercooler. I wanna keep the stock bottom end in it. Plans are to pick up a set of Patroit stage 3 heads CNC'd. Also planned on going a ms4 camshaft?? was recently told that patroit heads arent good because of the 1.60 intake valve. 1.55 makes more power??? and that a MS4 camshaft wouldnt do me anygood on stock displacement ls1. I was also told that a 230's cam would better suit that STS i want a good healthy cam sound yet make power? i guess im lost on what cam would work best and also heads but not looking to spend more than 1600 or so on heads!! ANY HELP WOULD BE AWESOME
"Overlap will cause boost to be bled off and thats never good for making power"
Yeap, you are right, kinda kept me from reading stupidities like the above quote.
I know that Ive talked to a rep at hawksthirdgen and they have a f-body with the 228R cam in it and said it drives great. now they also have the car on E85 so im sure that helps power production too lol
Of course we both know that where overlap occurs as well as if the cam is intake or exhaust biased from TDC makes a difference in the amount of pressure lost.
What happens is that you end up compensating lost pressure with extra amount to make up for that amount lost.
On street, I experienced that roughly up to 6* overlap is tolerable at relatively low boost levels without very noticeable side effects. After that you star seeing less returns for amount of boost injected.
I felt I needed to say something about this because I've also found that overlap can add exhaust volume to the exhaust volume that is already present and can actually aid in spool time and not hurt it. I've also found that opening the exhaust valve earlier to allow the pressure wave that is normally used to continue driving the piston downwards on the power stroke, can be used to spool the turbine and "overdrive" it. If you go too far though on the EVO you just end up losing torque that could of been used to propel the vehicle forwards under heavy acceleration.
This is just my opinion on it, and I'm sure you have your own as John@TSP has his. This is what I've found to work best in my cam grinds.
IVO>0
IVC>48
EVO>48
EVC>0
ECL> 114
OVERLAP>0
Here are my valve events for JoshuaGrooms rear mounted T76 turbo:
1
45
53.5
1.5
112ICL 114LSA 116ECL
2.5 degrees overlap
I feel that since the turbo is mounted in the rear, that the exhaust pulses once they reach the turbo will be much weaker than if it were front mounted. For this reason I like to add a little overlap to get some unburnt fuel/air mixture added to the already spent exhaust gases that make up the majority of the exhaust volume already present. With the cams that I do, I've found that using this method verses others spools the turbo quicker. Too much overlap though will choke the exhaust housing/turbine wheel and cause the engine to peak at a much earlier RPM than if less overlap was utilized.
I also have found that if you open the exhaust valve later, the pressure wave is used up more in driving the piston downward, and the resulting pulse that leaves the exhaust port is weaker than if you opened it sooner. I've found that this helps "overdrive" the turbine wheel, but as I said earlier too much will result in loss of torque that could of been used to propel the vehicle forwards under acceleration. Too much can also cause excessive drive pressure issues.
I'm also closing the intake valve earlier with my profiles for rear mount turbo's in order to build more cylinder pressure which will add torque across the board which will help accelerate the car faster and help combat the lag that rear mount set-ups are known for.
Camshaft profiles are all a giant compromise and about balance. We're just trying to find that happy medium that performs the best.
