Heads and Cam
Old Jan 26, 2011 | 07:18 AM
ryany's Avatar
Default Heads and Cam
Do any of you guys kno how far I can cut the heads down on TSP 5.3 2.5. I will be running a TRAK Cam and I dont want to have to fly cut the pistons any advice?Thanks RyanY
Old Jan 26, 2011 | 08:29 AM
RARON455's Avatar
Mine were cut to 59ccs, your best bet is to contact TSP their customer service is second to none. If you measure your valve drop you can get a custom cam specced out. I have those heads with a custom cam and ported fast 92 and mine laid down 463 rwhp on their dyno, on my stock short block
Old Jan 26, 2011 | 08:36 AM
98 z28 mullins's Avatar
buddy of mine from here has those heads that were worked over and has a custom ground comp cam with a 92/92 combo and put 460 down with a stock shortblock that has 184k on it and the car runs plum wicked and sounds really nasty in a very good way i agree with raron455 customer service call is the way to go with that question
Old Jan 26, 2011 | 08:46 AM
ryany's Avatar
Thanks guys.
Old Jan 26, 2011 | 09:10 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
What are the specs on your cam? We can look at them and make an educated GUESS at to whether or not it will clear.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 26, 2011 | 01:59 PM
SNLPerformance's Avatar
Real close to the TorquerV3, except an XER exhaust lobe instead of XFI...don't think he's going to be able to mill
Old Jan 26, 2011 | 02:04 PM
TorquerV3 (231/234 .643"/.598 111LSA) we're able to mill about the 5.3's to about 60cc's without issues with piston to valve clearance on flat-top pistons!
__________________
Old Jan 26, 2011 | 08:30 PM
ryany's Avatar
It is a 231/234 .640/.590 112LSA
