slp headers help!!
Old Jan 28, 2011 | 01:09 AM
blackwidowSS's Avatar
Default slp headers help!!
I just installed some new slp headers on my 2000 camaro ss and they came with a y pipe and high flow cats..I also have straight pipes..I got the car today and after i finished putting gas..the service engine light came out I checked almost everything and it seems to be good and tight..what can it be??
Old Jan 28, 2011 | 09:36 AM
RARON455's Avatar
its prolly a sensor somewhwere,,,First check all your O2 sensors, then the coolant temp sensor, make sure they are all plugged in. If you dont find anything have the code read and it will tell you what is wrong. autozone can do this for you.
Old Jan 28, 2011 | 09:41 AM
Paul 1953's Avatar
Yes, installing headers throws a code, even with cats & O2 sensors. You should have it retuned now anyway. Mine ran harmfully lean after I put my lt's on.
Old Jan 28, 2011 | 09:44 AM
vaticano's Avatar
That is normal when putting on headers. Insufficient switching, is what the codes are for. The o2 sensors wont get hot enough to keep the PCM happy. You have to turn off the enablers in the PCM via a tuning software.
As stated above double check any wires and sensor plugs around where you worked or get it scanned to find out what the codes are for. But likely it's from the o2 sensors.
Old Jan 28, 2011 | 09:56 AM
Alright thanks guys! I will get ot retuned..but would running lean harmy car? At least until I get it tuned?
Old Jan 28, 2011 | 10:45 AM
5.3LJimmy's Avatar
Maybe it's because you installed them inside your engine? Most likely the O2 sensor heater efficiency codes.
