PR lenght
Old Jan 29, 2011 | 01:37 AM
offroadfury6's Avatar
Default PR lenght
How do you determine what size Pushrods you need? I am doing a simple Heads/cam setup with 1.7 rockers and supporting mods...will any of this affect it? what about the Head gasket size? How do I determine what thickness gasket I need as well?
thanks guys...
Old Jan 29, 2011 | 01:47 AM
Whiteaw57's Avatar
use a stock headgasket. get a pushrod length checker and simply check. there are plenty of write ups on the ins and outs. just do a quick search.
Old Jan 29, 2011 | 01:58 AM
did search...came up empty handed...
I've always found the search button to be a bigger waste of time than just asking...
-just sayn'
Old Jan 29, 2011 | 02:04 AM
Whiteaw57's Avatar
although I agree. I simply do not feel like typing the full thing out. Basically its pushrod checker, cam on base circle, go to zero lash, tighten rocker to 22 lb/ft, adjust PR checker to determine length and then factor in preload for whatever lifter you have. i think 0.030 is a good number for most LSX lifters but Its definitely 3 am and I could be forgetting something or have that number wrong. Anyone else feel free to chime in
Old Jan 29, 2011 | 02:08 AM
Whiteaw57's Avatar
https://ls1tech.com/forums/generatio...cam-guide.html
heres the cam guide. pr length is about half way down
Whiteaw57's Avatar
quick search.....
Old Jan 29, 2011 | 03:11 AM
alright i'm guessing stock or use a PR checker your describing...
Guess I'll do some reading.
Old Jan 29, 2011 | 03:14 AM
ahhhh!!!!! Pushrod length example pictures of too short and too long not showing...
anyone else chime in?
