H/C/I, should I rebuild the shortblock?
I suppose I should start off with my planned list of modifications and let you help me decide if I should rebuild my 99 LS1 76K shortblock . Or would I be fine leaving it alone?
Engine Related Mods planned:
Fast 102mm intake
92MM TB
Fast fuel rails
Bosch Green Injectors
CNC ported 243's w/ 5 angle valve job
Crane Dual Springs
LS2 Adjustable timing set
Custom grind Comp Cam 220/224 .581 .581 112 LSA
Kooks 1 7/8" race headers
Comp Cams Rockers, lifters, and -.050 pushrods.
This is an NA car, I don't plan on spraying either.
I drive it to work occasionally and race at the track 3-4 times a year. I do plan on installing ARP rod bolts.
Thanks in advance for your input.
Fast 102mm intake
92MM TB
Fast fuel rails
Crane Dual Springs
