PAC 1518's w/ LSL cam lobes, OK?
Depends on weight of valves though as well. I would go with a spring like the 26926 or 1521 or PRC EHT or similar etc. as the 1218 is kind of marginal for anything heavier than normal with that lobe. Even then it needs to be set up correctly as well.
Any opinions on the Lunati dual spring kit #73925K1LUN, the springs are made by PAC w/.660" lift ?
BTW, I've got AFR 205 w/AFR valves.
http://www.lunatipower.com/Product.aspx?id=478&gid=193
http://www.lunatipower.com/Product.aspx?id=2584&gid=322
