How to degree a TSP220
Old Jan 30, 2011 | 11:46 PM
LSJEEPandC5VETTE's Avatar
Default How to degree a TSP220
Quick ? I am installing a TSP220 into a 5.3 and I got a double roller timing chain set along with it. The smaller sprocket has -8 through +8 in 2 degree increments, which one do I have to set it at? Do I need a degree wheel? How many degrees should I have with the 220? Thanks.....
Old Jan 30, 2011 | 11:49 PM
Whiteaw57's Avatar
that refers to cam retard/advance. just depends how you want to shift your torque and HP curves
Old Jan 31, 2011 | 12:16 AM
So basically if I want to have it set for what they intended it to be just leave it at 0?
Old Jan 31, 2011 | 12:55 AM
Whiteaw57's Avatar
being a 220 yeah 0 isnt bad. basically if you want more low end torque and to hit the peak power later go with a negative advance. if you want to hit the HP sooner with a little less low end torque (this is what id suggest for a street machine, less revs) go with a positive advance. I wouldnt go over 2 degrees either way though. Let me ask two questions, what vehicle is it (how heavy), and what transmission?
Old Jan 31, 2011 | 12:56 AM
Whiteaw57's Avatar
after reading your username im gonna guess its a with a jeep
Old Jan 31, 2011 | 10:14 AM
Yeah its in a 99 wrangler with a 5.3 and its a stick..... 4.10 gears.
Old Jan 31, 2011 | 10:38 AM
voda1's Avatar
Check out this thread: https://ls1tech.com/forums/generatio...dyno-data.html
Old Jan 31, 2011 | 12:19 PM
Whiteaw57's Avatar
If it were me I would lean to either 0 or +2
