Mls head gaskets reusable?
Old Jan 31, 2011 | 06:58 PM
adrynalinjunkie's Avatar
Default Mls head gaskets reusable?
I'm assuming the answer to this is no but I thought I would ask
Old Jan 31, 2011 | 07:21 PM
Darkman's Avatar
My answer is no, but if you are patient someone will eventually chime in with a yes.
Old Jan 31, 2011 | 09:59 PM
Whiteaw57's Avatar
haha true dat darkman. Whatd you do with it? torque it down then have to pop it back off?
Old Jan 31, 2011 | 10:03 PM
trans_am7935's Avatar
i would like to know too cause i am getting me a set of them, but i would assume no.
Old Jan 31, 2011 | 10:10 PM
Whiteaw57's Avatar
to my knowledge the only reusable head gasket ive ever heard of was a copper one. with other head gaskets if you run them at all the answers pretty much no, but if you just torque them down and notice a problem and pop them right back off you might get away with reusing them maybe 7 out of 10 times (not saying its a good idea to try).
Old Jan 31, 2011 | 11:39 PM
01ssreda4's Avatar
I have heard the MLS gaskets are reusable. However, that doesnt mean I would trust them. I mean who the hell wants those kind of problems where you have leaks or coolant dumping into your oil and you have to go back and remove the heads. I have also heard that MLS gaskets are less forgiving for unmilled surfaces. So if I was not going to mill the heads flat I would run the regular $20 Fel-Pro specials. I have always milled the heads in the past and they have always sealed.
Old Feb 1, 2011 | 12:15 AM
blazer427X3's Avatar
You nailed it Darkman.
Pitch em and get new ones. Its worth the peace of mind.
Old Feb 1, 2011 | 01:10 AM
Whiteaw57's Avatar
^^^agreed, peace of mind is a wonderful thing
Old Feb 1, 2011 | 11:52 AM
SideStep's Avatar
I have reused Cometic MLS (.045), twice... no leaks. I was also using ARP head studs. This was with AFR205s, 62cc.
BTW, I use the copper spray sealant also.
Good Luck,
Old Feb 1, 2011 | 12:46 PM
Whiteaw57's Avatar
^^^i think the studs and mainly the spray sealant has saved yours
Old Feb 1, 2011 | 03:55 PM
PREDATOR-Z's Avatar
MLS in good condition are reusable.
Old Feb 1, 2011 | 05:05 PM
WS6tx's Avatar
And there's your yes!!
