TSP 228R After Tune!
The car when brought to me was misfiring from being so rich....that's why it only made 330whp on its first pull....the gains were true and the car was running a nice 12.8:1 AFR with 25* timing on 93oct....I did NOT fudge any numbers to impress and would never dream of it...ENJOY!!
-Jack
Changing the Parasitics Multiplier will "not" effect how the Dyno loads, it only changes how the numbers are displayed in the end. There are calibration measurements made by accelerating the rollers to certain speed, place the car in neutral or clutch in & letting the rollers coast down, this is done several times. Parasitic curve is the fancy name, if I remember correctly. The Multiplier is used to caculate from that curve what final numbers are displayed, no effect to loading.
Thanks BoostCry for clarifying your Dyno Parameters!
Thats the number you should be swingin for
zo6's dyno anywhere from 420-450whp, depending on dyno, cam size, and supporting mods...
... but not realistic with the mods to the car. 400-405 rwhp would be alot more realistic numbers for that combo.
