Got a touqer v3 bt blew my bottom end what should i do?
hey i hav a 02 ss i blew my bottom end i jus put a touqer v3 cam i really liked the cam which block should i go wit?
What caused it to break? Did it drop a valve or what?
If the block isn't hurt, you can put a set of forged pistons and rods and spray it then or you can build something like a 370 or 408 iron motor and go that route. Iron will definitely be cheaper if you can not reuse your block.
Jon
Jon
Jon
Jon
If you do switch cams get one with a good exhaust split like the 233/239 you want something that pushes the air out since the nitrous is getting the power in the engine.
