What is a pushrod valve gear
Old Feb 12, 2004 | 03:53 PM
Rocket-Doc's Avatar
Default What is a pushrod valve gear
I've built a dozen motors, so my knowledge isn't thin, but what is this pushrod valve gear that the LS1/LS6 has and what is it's purpose?
Old Feb 12, 2004 | 04:50 PM
Tin Indian's Avatar
pushrod valve gear?
No such an animal in the list of parts.
Old Feb 12, 2004 | 05:13 PM
Tally TransAm's Avatar
is that like exhaust bearings???
Old Feb 12, 2004 | 05:15 PM
Paul F's Avatar
Originally Posted by Tin Indian
pushrod valve gear?
Sure there is. I think it on the same isle as the chain stretcher.
Sorry man can't say as I heard of those either. Maybe that's what they are calling a camshaft now days.
Old Feb 12, 2004 | 05:46 PM
2001CamaroGuy's Avatar
could they mean a "pushrod actuated valve gear" (valve gear = valve train)?
The term "valve gear" is an old term for the system that operated the valve to admit air/steam/fuel/etc....
Old Feb 12, 2004 | 06:31 PM
Kens_02SS's Avatar
Old Feb 12, 2004 | 06:39 PM
NataSS Inc's Avatar
OH I know what that is. Its down isle 2 left hand side right next to the blinker fluid.
JK
I have never heard of anything like that in the LSx related world.
Old Feb 12, 2004 | 06:51 PM
T/A Medic's Avatar
is that next to the boost fluid?
Old Feb 12, 2004 | 07:43 PM
stroked 4.8L's Avatar
yeah, its located by the flux capacitor and the kanutor valve actuator door, over by the 2-stroke rotary turbo diesel connecting rod.
cueball's Avatar
JK
yes, one isle down from the prop wash, and left handed pipe wrenches
sorry just had to add in hehehe
Old Feb 12, 2004 | 08:20 PM
Orange Juice's Avatar
While your at it can you pick up the bating tool. There is a master and a minor, I want the Master.
Old Feb 12, 2004 | 08:26 PM
WOT's Avatar
WOT
1.21 jigawatts???? what was i thinking!!!
Old Feb 13, 2004 | 10:53 AM
Tin Indian's Avatar
I think "Rocket-Doc" may have been scared away.
Old Feb 13, 2004 | 11:18 AM
Steve Burger's Avatar
LS1TECH Sponsor
Come on, the guy asked a legitimate question so give a real answer.
A pushrod Valve Gear is a miniature gear inside of each pushrod. I am sure that you have seen a number of post on bending pushrods with missed shifts or mechanical overevs. The aftermarket has addressed this with a new style pushrod. This has a gear actuated valve inside the pushrod to allow for beed down in a situation that would bend a normal pushrod. These are new and somewhat untested to date. I have not purchased them myself as cost is a factor. Also do not know if any sponsors carry them yet.
Old Feb 13, 2004 | 03:20 PM
Gary Z's Avatar
Do all you comedians remember that "gear" is a word with multiple meanings?
I found the likely source of Rocket-Doc's confusion on the Idaho Corvette Webpage www.idavette.net in a description of the 2001 LS6 engine.
This new Gen III puts out 385hp at 6000 rpm and 385lbs/ft torque at 4800rpm. A dozen years of engine technology advancement gets us 10 horsepower and 15 pounds/feet torque with identical peaks. If that doesn’t seem like much, consider that improvement comes from an engine with: slightly less displacement, smaller physical size, only one cam, only two valves-per-cylinder, pushrod valve gear, less weight and better fuel mileage.
The point is that this engine doesn’t have overhead camshafts. Rather it has “pushrod valve gear”
-Gary
Old Feb 13, 2004 | 03:41 PM
SSideExhLS1's Avatar
yes, it is like a pressure release solenoid for the kanutor valve
