What heads to lower compression?
Old Feb 12, 2004 | 05:17 PM
kjmdrumz3's Avatar
Default What heads to lower compression?
I would like to eventually run around 14#s of boost. I would think I need to lower my compression to somewhere in the 9.1-9.4 range? What would be a good set of heads and cam to do that?
Old Feb 12, 2004 | 05:28 PM
2001CamaroGuy's Avatar
6.0 L truck heads are an easy setup......
a) they have a larger chanber which lowers compression
b) they have the "LS6" ports which flow better
c) they are cheap
