Biggest Smog Cam With Stock Cats
only a few counties currently do and mine if one of them. Newer cars only get obdII and visual checks. Even though my car is ls1 swapped its supposed to be obdI gets a sniffer and visual even though the obdII port is available.
California's emissions laws will only get worse...
Been considering becoming a new resident of Texas in the future.
Based on what I'm reading here, it appears that much of Texas doesn't have emissions test other than the counties mentioned below ?
http://www.txdps.state.tx.us/vi/insp.../item_insp.asp
Emissions Testing Procedures
Is your vehicle required to be emissions tested?
All Texas registered vehicles are required to receive an annual inspection. All inspections include a comprehensive safety inspection; however, some vehicles are required to have an emissions test in addition to the safety inspection.
Which vehicles are required to have the emissions test?
Vehicles registered in designated counties. Designated counties include: Brazoria, Fort Bend, Galveston, Harris, Montgomery, Collin, Dallas, Denton, Ellis, Johnson, Kaufman, Parker, Rockwall, Tarrant, Travis, Williamson and El Paso counties.
Gasoline powered vehicles. Diesel powered vehicles and motorcycles are exempt from emissions testing, but are still required to have the annual safety inspection.
Vehicles 2 through 24 years old OR upon expiration of the two-year initial inspection sticker.
![](http://www.txdps.state.tx.us/vi/images/emis_counties.jpg)
because i was gonna say that u should leave your car alone and smog it with what u have. than in 2013 when its time for the smog u would not have to worry about the sniffer anymore, just a OBD2 scan and can put whatever cam u want in your car. but since your car is not a 2000 or newer that law will not apply to u.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Or I could buy a small shot gun shack somewhere out of a major town with a mailbox.
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
It should, it's actually got less over lap than a 224/224 114 LSA cam. It wouldn't work well for a restrictive stock exhaust like I've got planned though. It would need to be an exhaust biased cam to help crutch such a restrictive setup.
#32
ya but that about as big as you can go you will need a good tune, it will also be pretty hard on valvetrain.
well you need to list the exhaust you got planned if you want help as far as cam advice. your sig says you have longtubes
something like the cheatr v3 would work well with stockish exhaust
#33
![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
#34
I've been wondering if there is anyone in California running a LS2 block/L92 heads or LS3 long block in a 4th Gen F-body, with a larger cam, that has legitimately made it through a smog check.
#35
I am sure there have been or that could be easily done but i dont believe the cost is worth the power gains.
#36
yup thats my bad, i still suggest the cheatr v3.
as CI increases it effectively decreases the size of the cam so to say, so the more cubes you have the more you can get away with but you are still limited by the factory cats and manifolds.
If my motors goes, it would be fun to go with more cubes.
There are guys running nice 500 rwhp normally aspirated with LS2 6.0L blocks and L92 or LS3 heads. But this in less restrictive states.
#38
If it wasn't for California emissions, I would just go with a larger cam, long tubes, bigger injectors, EGR, airtube, airpump removal and a good tune.
ya with as aggressive as that cam is i would say it would act more like a 228/228 though but still should pass with a good tune/cats
#39
Google camshaft overlap. Wallace? has a cam spec calculator that might help you. Try to stay under -4 degrees. Overlap is the killer for Calif. smog. Hope this helps!
