Biggest Smog Cam With Stock Cats
#61
Great thread: Just to give more input on the CA situation... One problem I have run into is that they are getting really fussy about the visual inspection - checking things like long tubes, legal CATS. I used to be able to find someone who would pass it for about $200, they have all (the ones that I used anyway) been shut down (our tax dollars at work). I am sick of the whole business. I was running a 220/220 on a 112 with long tubes with SLP 3" cats and was tagged as a gross polluter. At present I am putting a 2004 LS6 cam, JBA shorties and fabricating a custom 3" exhaust system. I am using CA legal Magnaflow cats (2.5"). We'll see how it goes. The HS 1.8 rockers provide approx. .580 - .590 lift and I'm hoping passing SMOG becomes routine. I mostly AutoX the car, so I don't need HP, I need torque. I'll let you know how it turns out. Good luck to us both.
#62
True..but he wants to use shorty headers for smog, and a single pattern cam like the 220/220 would be a poor choice. You need a cam thats exhaust biased for a shorty/stock manifold setup. The cheaTR cam or the EPS one thats designed for a restrictive exhuast would be the way to go IMO.
#63
http://www.engpwrsys.com/index.php?a...od&productId=9
If I don't sell my car, this is the cam I will probably be using. This would be great for stock manifolds/shorties, and sounds like its easier on the valvetrain than the cheaTR v.3.
#64
That looks pretty interesting.
EPS reccommends dual springs.
You could also go with something like the PAC 1518s, unless you have good springs allready.
http://www.pacracing.com/Street_Stri...Set_of_16.html
#65
cuz i was just curious. after reading this thread it has made me think a lil bit about my setup. i most likely was gonna go with a cam that would work with my exhaust manifolds. but after reading this i am thinking about just going with a normal cam.
did u just put on the stock exhaust parts with your 224 cam and drive into the smog station and it passed? or did u need to have it tuned with your stock exhaust parts to have it pass?
#66
#67
With this EPS Cam I wonder if the profile is comparible to Comp's XFI or XE lobes.
Some cams even use dual profiles which will require different length intake and exhaust pushrods.
#68
#69
i literally just drove home from the smog shop and my TR224 114LSA passed with EASE with stock manifolds, cats, etc.! I also have a 3800 stall and ported and polished LS6 59CC heads. My buddy passed smog with a bullet cam 222/226 .595"/.585" although I forget the LSA. Here are my results for those who are interested-
15mph- c02 13.9%/ O2 0.7%/ HC 14PPM/ CO .17%/ NO 162PPM
25mph- c02 14.0%/ O2 0.6%/ HC 10PPM/ CO .18%/ NO 147PPM
now of course this was with a good driveability tune, but as you can see if was no where close to failing!
#70
You passed with flying colors. Very encouraging.
#80
update, i have run a best of 11.9@111 with a few suspension tweaks and a one legged 10 bolt. rear end is getting rebuilt now with 3.73s and a couple more suspensions tweaks. hoping to see a couple tenths improvements.
