gear change + exhaust setup
Old Feb 11, 2011 | 03:24 AM
bwarren337's Avatar
Default gear change + exhaust setup
I was wanting to know if I had to change the gears in my car or would it be alright to keep the stock gears?
Running off the headers would a x pipe into a 5" turn down be better or running pipe off the headers to 3" turn down pipes be better?
I have a 1999 Z28 that has 96000 miles. Im putting a ms4 cam in and new springs, locks, retainers, pushrods, pro 5.0 shifter, spec stage2 clutch, hooker headers 1 7/8 3", ported ls6 oil pump, and ls2 timing chain. I already have ls6 manifold and ported throttle body.
Old Feb 11, 2011 | 09:45 AM
Steve Gunn's Avatar
You don't HAVE to change gears, but 410's or 430's would be a better match for your cam. 3" exhaust is fine.
Old Feb 11, 2011 | 10:10 AM
WSsick's Avatar
Gears will make life with that cam much nicer. It loves to be in high rpms, so 4.10s would be a good choice, 4.30s if you really don't mind big rpm cruising. 3" tubing will be more than sufficient.
Old Feb 11, 2011 | 11:37 AM
ballinboyz44's Avatar
higher gears take down on your top speed tho right?
Old Feb 11, 2011 | 11:53 AM
WSsick's Avatar
Yes, but how often do you go high enough to make that matter? The raised redline will allow for extra rpm in each gear as well. If a race isn't over by 130/140, that's good enough. Hell, most of the time it's more than over by 110.
You don't want keep top speed but sacrifice your powerband. With 3.42s, you might fall just a tad bit out of the strong pull of that cam. I'd rather have that then the ability to go 160, which is never used 99.9% of the time.
Old Feb 11, 2011 | 08:14 PM
Steve Gunn's Avatar
My top speed is 171 at 6800 in 5th with 411's. I'll just have to live with it.
Old Feb 12, 2011 | 10:39 AM
bwarren337's Avatar
so if i were to go with 4.10 gears would there be a specific brand that makes good strong gears that are reliable and efficient.
