Blown Head Gasket ::Need Advice::
The car is only an exhaust and intake car at the moment and want to know what should be replaced when I do the change. I will be using the same heads and I have read that I need to resurface them. Anything else that I should know or replace while everything is apart?
The car is a 2000 LS1 Camaro Z28 M6 with about 123K miles...I have never done a repair this big so any advice on parts or process would be very useful and greatly appreciated. Thanks in advance.
GM MLS Head gaskets
ARP head bolts
LS7 lifters
surface the heads (not much though if you dont want to tune the car.
Best deal:
GM MLS Head gaskets
ARP head bolts
LS7 lifters
mill the heads
cam
timing chain
oil pump oring
valve springs
trunion upgrade for the rockers and hardened pushrods (might do these while in there anyway. $109 is all
Dyno Tune
Good luck!
be sure to follow the head swap guide perfect and figure out how you want to clean off the block before you start. Aluminum is soft so be careful, It pretty much needs to be as close to a mirror finish as you can get
@djfury: right now I think I'm just gonna fix it...I'm definitely gonna mod it down the line and do a head/cam swap but I also wanted to weigh my options...it's a DD so until I get another car I'm only doing basic bolt-ons...what would your suggestion be?
Take it apart and find out how much is reusable.
Try and figure out the root cause of why it blew the head gasket. They normally don't just blow at a certain mileage. If you don't correct the "reason" it may well blow them again.
No need to get worried about what your going to need till you have it apart and can determine damage levels.
If the heads are seriously warped or have deck material missing you'll then be thinking about head swaps now rather than later.
If the bores are trashed you'll be thinking about engines.
Best case will be headgakets, head bolts, minor gaskets, fluids, All cheap IMO. Occasionally you don't even need to have the heads resurfaced.
I've done slap together/make it run type repairs that lasted far far longer than they had any right too.
I once J/B welded a missing chunk of deck surface between 2 chambers that went over 10 K miles. I guessed it would live 90 minutes. I was WRONG.......
DO NOT purchase any parts till you really know what you need.
Hope this helps.
Now the following happened about 2-3 months ago: I had been hearing a weird noise coming from the engine bay at idle but couldn't figure it out...one day on the freeway it just overheated, power steering went out and so i got a off the freeway and i pulled over (temp. needle was in the red maybe for like 3-4 min while i managed to exit in rush hour traffic)..turns out the belt snapped and tore my belt tensioner to crap...replaced that and the belt and everything seemed fined.
2 weeks later it overheated on me again on the freeway but after i pulled over and let it cool for a few minutes it was fine...did it to me once more till i got it back home. Turns out it was a water pump leak, so I replaced the water pump, put in a new 160 tstat and new coolant temp sensor and filled her up with 50/50 dexcool...fired her up and let her sit with the radiator cap open to bleed the system and it overheated once more. I let her sit for a day and the next day i fired her up once more and everything seemed fine...topped off the coolant after the stat opened and she's been ok ever since.
Now, i do have a check engine light for a knock sensor...changed the sensors and replaced the harness twice and the light just keeps coming back...when I pulled the intake both times there really wasn't much oil coming from the intake if any at all. I am leaking pretty bad from the valve cover gaskets and the guy that did my exhaust said I have a bad rear main seal...she slowly seeps oil from down under by the oil pan but its not like dripping or anything.
btw djfury to answer your last post i have about a $600-800 budget..I want her running in tip top shape...for like 2 years at least before I do a head/cam swap
@technicalninja...that is also good advice...thanks for all the help and suggestions fellas
