Blown Head Gasket ::Need Advice::
1. Get a compression test gauge and fitting for your sparkplug hole.
2. Disconect your fuel pump fuse or fuel pump relay.
3. Pull ur spark plugs
4. Screw your compression test gauge into the spark plug hole
5. Let the engine crank over 4-5 times and watch the gauge. Your number should be between 130-160. Pay close attention to the cylnder that had oil on the spark plug. If it is low like 115 or less than poor a little oil in the cylnder, screw your gauge back in, crank the car 4-5 times and watch ur gauge. If your numbers went up, than you have a bad piston ring. If the number stayed the same and is still low, you need to check the heads...
Best method: with a battery charger attached to car to reduce the battery drain that usually produces lower readings on the last cylinders. Another running car with jumper cables can substitute for a battery charger.
Remove all of the plugs.
Disable the ignition/fuel. Jam throttle open.
Spin engine over while watching the gauge. In your case it would be easier to have a helper in the car turning it over and holding the throttle open. I usually count 10 "hits" then stop. Write figure down. I use a dry erase marker on the windsheild.
Test the other cylinders with the same number of "hits" on each. Watch how fast the reading come up. Usually the needle stops gaining after 4-6 hits. Have a slow one? You may be seeing the beginnings of a problem.
Compare readings. Post results on here.
Remove throttle block BEFORE putting car back together. Trust me on this! Even I have forgotten about the throttle being open...
ONLY ONCE!If your using a helper this will not be a problem.
If you find issues with the compression test you will not have wasted time and money "repairing" other things that were not the root cause. "Throwing money" at a problem usually doesn't fix it.
If you don't have a comp tester already you may NOT be a tech. Think hard about having someone more knowledgeable diagnosing the car. You may be money ahead!
My tool box(s) weighs FAR more than my car and I have more money in tools than I have in my house. The wallet vampires (Snap-On/Matco tool dealers) know me well.
It's addictive if your really a tech.
If I won the lottery I would still wrench on stuff. The "stuff" would be more expensive.....
Only after a good comp test would you look for other reasons....
Next stop would be PCV system. New valve and connection check.
ASE double master-Automotive/Machinist.
Diagnose first!
Then spend money..... do cheaper PM type stuff first. You'll be pissed if you change the stem seals in the car and it turns out to be a bad PCV. I believe in AC/Delco parts for these cars if possible. Seen too many "oh this part will work" screw ups to try and save chump change...
Your next post should include comp readings.
Good luck!
