fast 90 install help
Old Feb 11, 2011 | 03:32 PM
02sslayer's Avatar
Default fast 90 install help
i am in the middle of installing my fast 90, and i have two questions.
Q#1 can i use my mounting bolts from my ls6 intake?(to bolt it down to the engine)
Q#2 what are the torque specs for tightening the bolts?
thank you much to anyone that has the answers
Old Feb 11, 2011 | 03:44 PM
rob00ss's Avatar
yes u can use ur stock mounting bolts. Ive actually heard there better than aftermarket and ls1howto.com has all the tourque specs ull ever need but first pass in 44 lb in and second pass is 89 lb inches. Just make sure u go in the sequence recomended and remeber its inch pounds and not foot pounds. Just take ur time and be carefull i snaped on off when i was putting my fast 102 on not much fun.
Old Feb 11, 2011 | 03:46 PM
smg267's Avatar
I got question # 1. Yes you can reuse your stock bolts to bolt the manifold on.
Not the right solution but I tightened my Fast Intake untill the bolts felt snug but not like I was going to snap the intake in half.
***Make sure you are using the flat washers for the valley cover and not the stock ones!! You will crack the intake.
Old Feb 11, 2011 | 04:04 PM
02sslayer's Avatar
thanks guys, i appreciate it alot. my intake didnt come with the mounting bolts(long story).
Old Feb 11, 2011 | 04:45 PM
bayer-z28's Avatar
Stock Tq spec for the intake bolts on the fast.
And most sponsors here sell the pan head bolts for the valley cover.
Old Feb 11, 2011 | 06:20 PM
garygnu's Avatar
OP did your intake come with the lower profile valley cover bolts?you must use them.
Old Feb 11, 2011 | 06:33 PM
02sslayer's Avatar
yes i have those installed. infact i have the whole intake wired up and botled down. but the bellows i got with it dont work. anyone know where i can find the correct bellows?
Old Feb 11, 2011 | 07:05 PM
garygnu's Avatar
try air flow systems or intake hoses.com
Old Feb 11, 2011 | 07:46 PM
02sslayer's Avatar
it turns out that the slp smooth bellows can stretch to fit. got the car running and it runs like crap hope its just the tune.
Old Feb 12, 2011 | 01:12 AM
LilJayV10's Avatar
Double check for vacuum leaks.
Keep us updated.
Old Feb 12, 2011 | 01:17 AM
ucanthangwme's Avatar
How do you know if you have lower profile bolts?
Old Feb 12, 2011 | 01:50 AM
02sslayer's Avatar
they are shorter allen head bolts.
Old Feb 12, 2011 | 02:04 AM
Squirts11's Avatar
Keep us updated.
x2. I had a vacuum leak after the intake swap. After a couple days of annoying troubleshooting, it ended up being an air leak from the stainless FAST intake bolts. Swapped back to the factory hex bolts, and the idle returned to normal.
Old Feb 12, 2011 | 02:10 AM
02sslayer's Avatar
i used the stock bolts as well. the car runs pretty damn good under throttle, the idle just aint as good. i really think its just the tune.
Old Feb 12, 2011 | 08:23 AM
^Did the idle drop or go up?
Old Feb 12, 2011 | 04:31 PM
02sslayer's Avatar
it just takes it a lil longer to find the correct point to idle at. but after a minute or so it idles fine
Old Feb 12, 2011 | 04:46 PM
LilJayV10's Avatar
If you haven't already, the car idling take some carb cleaner and start spraying around the T/B, down the sides of the intake and in back. IF there is a vacuum leak the engines RPM will raise up for a few seconds then go back down.
Even with a vacuum leak it will run OK under part/WOT throttle but is more noticeable at idle. The vacuum leak sucks air in after the MAF but before the 02 sensor. The O2 sensors see's it, thinks its running lean and then try's to compensate.
When you spray the carb cleaner on the vacuum leak it "richens" the A/F ratio until the carb cleaner burns away.
Old Feb 12, 2011 | 04:55 PM
02sslayer's Avatar
i have heard that from a few people so far, just havnt gotten around to doin it
