ls2 t chain
Old Feb 15, 2011 | 05:40 PM
spiro27's Avatar
Default ls2 t chain
is the ls2 chain a good upgrade and what oil pump can i use with it. is the crank sproket hard to remove off the crank. does the crank have a notch. thanks.
Old Feb 15, 2011 | 05:44 PM
spiro27's Avatar
can i use the ls1 timming chain gear on crank and cam gear or need new ones
Old Feb 15, 2011 | 05:46 PM
Jon@Texas-Speed's Avatar
Good upgrade if you are on a budget. You can run either a stock style GM pump or a Melling either one. Both shoudn't have clearance issues on a single chain. The lower gear isn't hard to get off. A small puller will do it. It is keyed as well. I would line it up dot to dot before you remove it so it is easier to put back together. Let me know if you have any other questions!
Thanks!
Jon
Old Feb 15, 2011 | 07:16 PM
Paul 75 L82's Avatar
I bought the LS2 chain kit and the Ported Oil Pump from Texas Speed. When I looked at my stock crank sprocket I decided to just go ahead and reuse it and just use the LS2 chanin and top sprocket. The Ported LS6 pump fit great.
