What can be expected from ported LS6 heads?
I have been pondering this question for awhile now as I am attempting to get over the 4xx rwhp mark on a budget. I have a friend here in Eastern N.C. who can set me up with a reasonable deal on LS6 heads and LS6 cam. I do believe however there is a better cam that would be ideally suited to the flow characteristics of ported ls6's. If anybody has any input on what I can expect from heads alone right now on my full bolt-on car it would be appreciated.
I'm the same mind set of you. I have 99 z28 that i going to built it in a budget set up this year because there is too much that i'm doing at the same time, new body paint , 8.8 rear end ,243 ported heads , MS3 ,42 lbs injectors ,high flow fuel pump, Roll Bars , Pro Satr weld racing and tires Hoosier Quick time pros and Nitrous 150-175 shoot .
if you're right that's why he mentioned it depends on who does the job porting the heads. But if the head touches the wrong person will damage them.
http://www.totalengineairflow.com/products/gmhead/gmls1/
or these guys>>>http://www.advancedinduction.com/AiProductsGMLS2.html
Personally i would call Geoff at EPS and have him grind you a 224/220 on 116 lsa. This cam will idle like stock and his lobes are superior to most so you wont have that sewing machine noise as much as you would have with other cams.
Look up the MTI stealth 2 camshaft, there are even some idle clips on youtube. Something along those lines would be perfect for you.
https://ls1tech.com/forums/dynamomet...22-7-rwhp.html
DJ you have a strong running car but stealthy it aint
