Is this normal for not being tuned?
Old Feb 17, 2011 | 11:05 PM
Greekey's Avatar
Default Is this normal for not being tuned?
Today I pulled my car out of the garage to wash it since it was pretty nice outside. I got done putting a cam, heads, and an intake on it last week. I fired it up and pulled it out of the garage. After I got done washing it, I tried starting it, and it didn't want to start unless I gave it a little bit of throttle. After that it began to idle perfectly fine. Is this normal for it being untuned? I just want to make sure.
Old Feb 17, 2011 | 11:58 PM
Blu99T/A's Avatar
Sounds normal to me. I had to prime mine and throttle it to get it to start before being tuned.
Old Feb 18, 2011 | 02:43 AM
kdavis's Avatar
I also have to prime mine ans give it alittle throttle to get it started. Once its running it idles high(1200rpm) not sure if that is normal or if I have a vacuum leak somewhere
Old Feb 18, 2011 | 11:22 AM
99Bluz28's Avatar
Same thing here, with a 227/231 111lsa cam, AFR 205's, BK LT headers, and I just got it running yesterday.
Old Feb 18, 2011 | 05:55 PM
99Bluz28's Avatar
If you have a hand held programmer bump the idle up about 100rpm and it'll stall less.
Old Feb 18, 2011 | 07:57 PM
Greekey's Avatar
Is this why some people enlarge their throttle body hole? Would I have to do that eventually?
Old Feb 18, 2011 | 09:12 PM
KevinR's Avatar
I wouldn't. I had to go about a week before I could get mine tuned, and it was a pain in the **** to start. It would take 4-5 tries to get it started. After you get it tuned, you should be good to go.
Old Feb 18, 2011 | 09:14 PM
99Bluz28's Avatar
I believe so, but I wouldn't if you're getting it tuned soon.
Old Feb 18, 2011 | 09:15 PM
Greekey's Avatar
10-4 Thanks guys.
