few lq4 and 853 questions
Old Feb 21, 2011 | 07:41 PM
pajamasam's Avatar
Default few lq4 and 853 questions
I got my 2000 lq4(stock iron heads) running in my 85 trans am and it runs great.
Today i got a set of brand new 853 heads milled .035" with z06 springs for a pretty good deal.
Whats my compression going to be with this setup?
They dont have the funny groove setup so what headgaskets should i use?
What would be a good street strip cam for this setup?
Just want to hear some hear some ideas, not in a real hurry and dont want to spend a ton ethier.
Old Feb 22, 2011 | 09:33 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
My calculator came up with 10.66:1 for your compression ratio. I calculated this with a stock MLS gasket and a 60cc chamber.
I would just use GM MLS gaskets for a setup like this. In order to recommend you a cam we would need some more info about the car. Is it auto or manual? If auto what size stall do you plan on running?
Old Feb 22, 2011 | 09:44 AM
pajamasam's Avatar
700r4 3000ish stall 3.73 gears. Stock car weight. I forgot to mention its carbed with vic jr.
Old Feb 22, 2011 | 11:54 AM
We would probably end up doing a custom cam for you. We like to run the 233/239 camshaft with carbs but I am not sure you have enough converter for it. something like a 226/232 would probably work out better with the stall you currently have.
Old Feb 22, 2011 | 05:25 PM
pajamasam's Avatar
Yea really i can pick whatever stall i want, but i had 3000 stall in my camaro from these guys and i really liked it. What stall would u recommend for a cam like that?
Old Feb 22, 2011 | 05:38 PM
Something closer to a 3500-3600 would be ideal for a cam like that. The 3000 might be ok, but the cam would operate much better with a larger stall. You should still easily be able to drive it around with that size stall.
