Top end package
Old Feb 22, 2011 | 04:51 PM
Bluvette28's Avatar
Default Top end package
How you doing i have a 2000 z28 that im looking to run mid to low 11s in. I have slp maf, 243 heads unported, bbk intake, pacesetter headers, 3600 stall, 3.73 gears, slp lid, bbk throttle body. Now my question what would be the strongest most powerful way of doing this. I was told get 1 7/8 headers, a fast intake and throttle body, and better heads and a cam. I want an aggresive cam at idle but dont want to loose to much low end any input would be great.
Thanks in advance. And i want this N/A
Old Feb 22, 2011 | 05:06 PM
earmuffs's Avatar
AFR 205, or TF 215 heads. ported. FAST 102/102 ported with a suporting cam. You will make lots of power and throttle will be very responsive
Old Feb 22, 2011 | 05:07 PM
Bluvette28's Avatar
Will it make that much of a diffrence if its not ported? Also what would be a supporting cam
Old Feb 22, 2011 | 05:09 PM
earmuffs's Avatar
The porting of heads and intake will increase your port velocity. Resulting in more air and fuel in your cylinders to make more power.
Old Feb 23, 2011 | 12:07 AM
Bluvette28's Avatar
Is a fast 90mm set up good or is the 102mm prefered. 102 sounds really big but im here to listen!
Old Feb 23, 2011 | 03:00 AM
earmuffs's Avatar
102 is better. 90's are a little harder to find, but for a 346 would do just fine. deffinetly better than the stock intake.
Old Feb 23, 2011 | 06:41 AM
garygnu's Avatar
try a custom cam and keep the stock 243s.the BBK makes good power and could get you in the 11.xx.
