Anyone ever run this Lunati cam?
Old Feb 14, 2004 | 06:24 PM
Deeavi's Avatar
Default Anyone ever run this Lunati cam?
LUNATI-55005 Camshaft, Hyd.Roller, Chevy/GM LS1, .534/.544 in., 222/230 @0.050, 114LS - says that this is a good pro street cam with chopy idle
I am thinking of buying this cam @ $350 from Summit. It sounds like it would be a good strong steet cam in my '98 A4 Z-28 I want something that sounds good, but wont give me any problems!
I am also considering this cam from Speed, Inc: CC-custom3 Excellent power throughout RPM. With bolt-ons, Stage 2 heads and proper tuning, 420 RWHP in M6 cars is obtainable Lift: .563/.563 Dur@.050: 224/224 LSA:114
What do you guys think?
Old Feb 14, 2004 | 06:34 PM
98SS Blackattack's Avatar
I would buy a converter first. I would get the TR224 over the lunati grind UNLESS your are going to spray
Old Feb 14, 2004 | 06:56 PM
Deeavi's Avatar
I am buying a converter, but I want to be able to run air, etc without having
surging and idle problems!
Old Feb 14, 2004 | 10:08 PM
cm02WS6's Avatar
The specs on that custom Comp Cams cam from Speed Inc are basically the TR224 specs. The TR224 is a very popular cam, and will yield many search results.
Old Feb 14, 2004 | 10:26 PM
Deeavi's Avatar
Thanks for your input!
I am going to order the Lunati 55006 with the same specs as tr224. It is a better price through Summit. I can save about $50. When you are on a budget every dollar counts.
Now I need the springs and push rods.
Old Feb 15, 2004 | 01:38 PM
mike c.'s Avatar
i've heard bad things about lanuti cams. a guy i know had the mti b1 cam,at that time mti used lanuti cams. the cam would not idle good,stalled at stop lights and did'nt seem to make good power.now mti uses comp cams,i have the c1 cam and from day one i had no problems even with no tuning. mti,speed inc,thunder racing and lg all sell great cams ,usually from comp.
Old Feb 15, 2004 | 02:22 PM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
I had that cam in my car over 4 years ago before tuning was available. It idled decent @ 800RPM, dynoed 365 RWHP 366 RWTQ and ran a best of 12.20 @ 115 MPH 1.82 60' with a 3700lb raceweight 3:73 gears and BFG DR's.
I would like to see what that cam would do with a good tune.
Old Feb 15, 2004 | 04:51 PM
GrapeApe's Avatar
I have a lunati 226/234/554/575 112 and its lopey makes good power--that cam has a huge split in the duration --might be a tuneing nightmare --my car made over 400 with stock valved heads and the 226/234 my cam may be for sale in 2 weeks or so if ya want to wait --250 is what i'll ask pm me if interested "waiting for my custom grind from FMS my cam has 3500k on it
Old Feb 15, 2004 | 05:19 PM
Deeavi's Avatar
Richie, Which cam are you talking about? The 55005 or the 55006!?!
Old Feb 15, 2004 | 06:07 PM
Deeavi's Avatar
I believe that is a little more cam than I want! I think I would rather go with the 55006 @ 224/224/560/560 112
Old Feb 16, 2004 | 03:30 PM
I was talking about the 55005 and stock heads. I also had the 55006 and ported heads as well. Both cams were great and had excellent drivability.
Old Feb 16, 2004 | 03:55 PM
Deeavi's Avatar
Thanks, The 55006 sounds like what I am looking for. What was your car auto or manual?
I talked to a tech at Lunati and he said that all I should need with that cam is a 2500 stall converter. Does that sound about right to you? I doubt if I race the car much right now since it is my daily driver, but I will run it some!
Old Feb 16, 2004 | 09:20 PM
URPREY's Avatar
I'm running the 55006 in my car, and a friend is running it in his A4 as well. With a little tuning it runs great and idles fine.
Old Feb 16, 2004 | 10:06 PM
GrapeApe's Avatar
I think --well i know mine is the 55099--will be for sale in a week or 2
Old Feb 17, 2004 | 12:04 AM
strokedls1's Avatar
I had the 222/230 and it was a good cam in its day. Idled fine with tuning. I now have a 242/242 lunati in a 422 that makes really good power. I would go with the tr224 on a 114 for emissions and drivabiltity. You'll make a lot power with that cam.
Old Feb 17, 2004 | 05:51 AM
antz01ta's Avatar
10 Second Club + 14 Second Truck Club
i just ordered a 230/237 .568 .568 114lsa lunati cam
i got it with a little more lift than the off shelf .545 lift cam.
this will me going in my 396 stroker, and should make alot of mid rpm
power with the stroker
