Glass media blasting LS heads
I recently brought a set of 317 heads to a machine shop to have them cleaned and checked. I was fully expecting them to put them in a solvent bath or something. When I picked them up, I found that they had removed the valves and glass bead blasted the castings everywhere (including head gasket surface, areas in contact w/oil, combustion chambers, valve seating areas, etc.). I was handed a box of valves with no markings as to where they go and the heads with beads still spilling out of thier tapped holes.
i was a bit concerned to say the least. i posted up on another forum and got responses ranging from "your engine will be trashed in 20 minutes" to "this is completely normal I have done this to countless heads, just clean them out good". I am hoping for a few more opinions so I'm posting up here.... should I be worried?
