Block, heads and cam question
Old Feb 25, 2011 | 12:26 PM
mcdonald77's Avatar
Default Block, heads and cam question
I think this is my first actually post since joining long ago!
I want to do a budget build, but not be a complete cheap ***. I got a set of L92 heads that I will use stock valves and parts, new or low mileage. I am looking at an LQ9 short block and wanted to put a Z06 cam in it with an LS3 intake. I have read through lots of threads and used the search function like mad. My question is will this combination be good? It will be in a daily driven 2 door Jimmy and not a race car. I am not hard on my engines, so I think the I can get away with low mileage parts as long as the machine shop says there ok. Also what year would I need to use a z06 cam from or does it matter?
Or would the same parts work with an LQ4 pistons and crank?
Old Feb 25, 2011 | 03:11 PM
5.3LJimmy's Avatar
The LQ4 would work with all the same parts that an LQ9 does. You will just be down about a half a point of compression with the LQ4. I would not recommend the LS6 cam with L92 heads. If you are set on using the LS6 cam then you would have better results with some 243/799 heads. On the other hand if the heads are what you want to stick with then I recommend going with a cam that has been designed around them. An off the shelf cam for a G8 or 2010-up Camaro would yield much better results with those heads.
Old Feb 25, 2011 | 03:20 PM
mcdonald77's Avatar
I really appreciate the information. I want to stick with the heads since I have them and will look for the g8 or 2010 camaro cam.
