AFR 205 vs TF 215
I have ran the afr 205 in the past with GREAT results. I'm sure the afr 210 head is even better. I ran the 205 head with a stock rocker and had no issues for years. I now run the trick flow 235 had with yella terra rockers. My boy has ran the same rocker for three years and i one so far with no issues. Both of us spin to 7,000 rpm's and are at or over the 500hp,10 sec n/a mark. Either head is money well spent and worth it in performance. The afr 205 head got me 4 tenths in 1/4mi over a top sponsor's ported head. The tfs head got me 2.2 tenths over a cnc ported l92 head and my 60's were a full tenth slower. They work!
I honestly gotta agree with you.. I know TFS makes a damn good product, especially when TEA does the magic, but i havent seen any vids of guys running TFS heads in action such as at the track, or street.. I am sure there are guys running 9's such as Vengeance customers, or guys that hardly post. But I even tried to do a search, and all i see is dyno numbers, or TFS head cars on the dyno. I want to see these heads in action. The only results i see are from hardcore drag racers. I want to see these heads on the street.
I have seen AFR heads, Ported LS6 heads, and TSP PRC heads lay the smack down on street cars. I havent seen anything with TFS. Not trying to bash, just my .02..as far as search goes, all i see is dyno numbers and hardly anything else.
I went with the AFR's for the same reason I didn't want to dick around with shimming/aftermarket rockers/goofy pushrods, etc. I'll be putting mine on this spring when the snow melts
Both are great and PI (old ETP) is just as good as either.
Kinda laugh at the guys commenting who have "this or that head" but have never seen the "other head" run but proclaim their preference. At this level it is more about the supporting combo than which head is better IMO. They are all top shelf and VERY close at least on a street/strip motor.... Never seen the PRC proprietary castings run but on paper they look good too. I keep looking for them at the strip...
#32
As far as which head is better, I only have a little experience with AFRs, and all i know about the TFS heads is from reviews on here.
I can say that I am VERY happy with my AFRs, and the service and knowledge that Tony Mamo provides makes them that much better!
BTW, im running AFR 205s with stock rockers, set up by Tony himself
#33
Both heads use bronze valve guides. I would personally run Yella Terra on either head. The higher lift of an aftermarket cam results in a wider wipe pattern with stock rockers then you will get with properly set up Yella Terra rockers. This will result in higher side loads and faster wear on the bronze guides due to the side loading. GM heads use a powder metal guide that is much harder and less prone to wear due to side loading.
Also, the AFR 205 is no longer available and has been replaced by the AFR 210. I prefer the AFR's over the TFS heads. Internet rumor seems to indicate that the TFS make remendous power over any other head, never seen the proof.
#34
Both heads need to run roller rockers since they both use bronze guides.
If your going to do that make sure you change the valve springs to the softer spring pressure like the platinum springs that tea uses. The original springs the are supplied on these heads are designed for the heavier tipped roller rocker. Using the heavier spring with the lighter tipped stock rocker will cause valve scrub and excelerated guide wear. I believe they will do this at no extra charge.
Pm coming your way.
Pm coming your way.
#35
One other race I had that was intresting was against a 2001 Z28. The owner just purchased the car two weeks prior so he only knew what the previous owner said. The Z28 put down 475rwhp (some dyno in Georgia) it had a Prochager with a blower cam. (unknown specs) When we lauched off the line it was pretty even until we hit second gear and I slowly started inching away from him. We shut down about 125 with me having about a half a car lead. I don't remember what all supporting bolton's he had but I think his car should have walked me pretty good. Could have been a bad tune, stock cam, or just a bad setup. Good runs though.
#36
The only heads I will ever run will have powdered metal guides and will run stock rockers. I checked the guide wear on the 4.8 heads off my 150,000 mile truck and there was NONE, once again, they come stock with powdered metal guides from GM.
