what grade oil to use next?
any engine builders/tuners able to offer advice on this one please?
i have a forged ls6 in a kit car used only for track days /sprints. the engine has been run in on mineral oil asadvised by builder, using 15w-50.
was advised to stay well clear of synthetic oil during the break in/running in period.
i did about 20mins/50m running in to cycle the engine, then droped the oil and changed it with new filter. since then it had about 100 miles on it driven quite hard on fresh oil. after that i did another oil swap at the start of last season (same grade) and caned the engine hard to the redline so it's definately run in hard now. its since done about 300miles on track last season.
its not time to get ready for this season, what weight /grade/type oil should i use. is it safe to use synthetic oil now or semi? or stick with the mineral?
i run 2 oil coolers and a dry sump so the oil has never gone above 100c on track. the engine runs great, uses no oil, and i am expecting to drope down a grade now to maybe 10-40 or even 5-40?
any advice appreciated.
have emailed same question to original builder but awaiting reply so far.
thats the only slight problem, they said to run mineral oil during the running in period and first few hundred miles, which i've now done. they advised not to use synthetic till then. i have emailed them asking the same question but no reply. (Weber race engines). i'm in the UK so not so easy to ring them to ask you see.
Is this for the GD T70? VERY COOL!!! Post some pics.
heres my photobucket link with the car in it.
http://s398.photobucket.com/albums/p.../GDT70%20Lola/
and a short vid of a launch. (on the old ls1, the day it blew up lol)
http://s398.photobucket.com/albums/p...t=MOV01277.mp4
I personally dont like to use synthetic oil at all...
especially not untill you are 100% sure you are fully broken in and all rings are fully seated..
granted you are not putzing about like the average person with your car...
but I would wait a while till you put in synthetic...several hundred more miles in my opinion...
as far as oil grade... I would stick with what the engine builder tells you to.
depending on tolerances, you may need to stick with that 15-50.
Non-synthetic oil protects normal engines just as good if not better than synthetics do.....synthetics are all marketing hype.
BUT....you have a purpose built race engine.......I would do exactly what your builder tells you to do, who knows what tolerances your engine was built to.
thanks for replies. i might stick with the mineral then a bit longer. oil temps are actually a bit low, with 15-50. the tolerances etc arent anything special, it was just a decent spec bottom end build (stock crank, carillo rods , forged pistons).
the car is a hoot tho!
our local costco had castrol magnatec semi synthetic on sale 10w-40 on a good offer with 2 gallons for £28 all in, which is what i normally pay for the mineral oil, i was tempted to run that this season, but might pass on it for now.
i think i will probably stick with a good mineral 10w-40 and do another season on this grade oil. i usually change it twice a season as i only do about 6 events per year anyway.
i did a proper heat cycle bed in,then with proper hard throttle after about 50miles of driving, as per the builders instructions, its not been allowed any risk of glazing. i just dont have enough experience of this to judge if this is enough thats all. mineral wont hurt it tho as people have said.
