Weak link in my forged motor?
Old Feb 28, 2011 | 09:54 PM
Adam86's Avatar
Default Weak link in my forged motor?
Building a low compression forged 347 for my TA. I was wondering what you guys think the weak link in my setup is if any. My plans are for ~600rwhp and will not be pushing it past the stock redline. Planning on a 9.2-9.4:1 CR. Also, if you have any ideas as to its power handling capabilities, give me your opinion Here's the build list:
-Stock '98 aluminum block
-New stock main caps and bolts
-Stock crankshaft
-Clevite Triarmor rod and main bearings
-Scat I-beam connecting rods with ARP 8740 rod bolts
-Diamond -9.6cc pistons with moly rings
-Melling oil pump
-LS2 timing chain
-TSP 7.400" hardened pushrods
-PAC .600 lift beehive valve springs
-LS7 lifters with new trays.
-ARP head bolts
-GM MLS gaskets
-241 heads
-Stock rockers
Thanks a lot guys. Wondering how much boost I should plan throwing at this puppy.
Old Feb 28, 2011 | 10:01 PM
got-a-ls1's Avatar
judging by those mods i would say anything that says stock in the driveline... haha motor shouldnt break a sweat at 600 rwhp.
Old Feb 28, 2011 | 10:43 PM
Adam86's Avatar
Ha well I have a monster level 3 clutch and flywheel so I guess ill play the waiting game with the rear end tranny should be good for a while I think.
Old Feb 28, 2011 | 10:44 PM
ss454327's Avatar
The stock LS1 block at #7 is the weak point. Sell it and go iron IMO.
Old Feb 28, 2011 | 10:52 PM
Adam86's Avatar
Iron for 600 horse? Doesn't seem like it would be worth the added weight.
Old Mar 1, 2011 | 12:17 AM
Detoxx03's Avatar
Don't need iron for the amount of power he wants go run.
Old Mar 1, 2011 | 12:37 AM
Adam86's Avatar
Good to hear, thanks man! I figure the weak point will probably be either the rods or main caps, both of which should pretty easily handle 650 rwhp I think. The rockers... well I figure when/if one goes I'll just get different stockers with the Comp Cam trunion upgrade.
Old Mar 1, 2011 | 12:49 AM
DONAIMIAN's Avatar
If your not gonna rev it I wouldn't even bother with an aftermarket rod, but that's me. Also go with the head studs over the bolts.
