Specs for machining 243's
Old Mar 1, 2011 | 02:07 PM
WVZ28's Avatar
Default Specs for machining 243's
Ok guys need a hand here. I have come across a set of 243's that a buddy was pretty much going to scrap because he is upgrading to a set of AFR heads. My question is he picked these up used and they were supposedly milled once? Who knows!!! Is there a point on these heads where i can mic to see if they truly have been milled. I have searched around on here but can't seem to come up with a good answer. When we take our heads to a machine shop i'm sure they have all these specs somewhere right?? And i will need those specs as well. Thanks
Old Mar 1, 2011 | 02:16 PM
pwrtrip75's Avatar
Measure the thickness of the entire head, from top of where the valve cover sits to the head gasket surface, that will tell you.
Old Mar 1, 2011 | 02:45 PM
WVZ28's Avatar
Default specs
yea i kinda figured that but what are the specs for the head to know if it has been milled or not. I need a factory baseline spec to start with.
Old Mar 2, 2011 | 06:36 AM
WVZ28's Avatar
anyone????
Old Mar 2, 2011 | 06:44 AM
garygnu's Avatar
cc the heads.
Old Mar 2, 2011 | 07:18 AM
Always2Slow's Avatar
Measure the ccs in the combustion chamber
Old Mar 2, 2011 | 08:45 AM
WVZ28's Avatar
Default specs
Thanks for reply guys...Anyone know how many cc's a stock 243 head is? Is there a reference for cc size to cr with stock pistons. At what point do i need to be concerned with flycutting? What is the minimal limit of pvc? I plan on claying the engine once i get a new cam. Thanks again for the info.
Old Mar 2, 2011 | 10:16 AM
Killer5.3's Avatar
Stock combustion chamber on 243 heads is 64.45 cc I believe. A good machinist can CC the heads and figure how much if any has been milled off.
 Michael S. Palmer
Old Mar 2, 2011 | 11:10 AM
RoidedSS's Avatar
https://ls1tech.com/forums/advanced-...ume-vs-cr.html
Old Mar 2, 2011 | 02:10 PM
WVZ28's Avatar
Great info thanks guys...I think i have come up with the stuff here at work to make my own burette kit. I'm gonna make up a stand so i can level up my heads and see what happens.
