Need input on new cam selection
Old Mar 1, 2011 | 04:30 PM
Intimidator02SS's Avatar
Default Need input on new cam selection
Been in touch with Comp to get a new cam. They are recommending the 54-424-11 (xr265hr). Duration is 265/271 (212/218). Valve lift specs out with my 1.8 rockers at .590/.596 lift. 383 cubes, m6 car, with stock port/polished heads, exhaust, ls6 intake. Already have supporting mods (springs, retainers, lifters, etc). Currently I'm at 550ish range of lift and looking for a little more but car is a daily driver.
What are your opinions, thoughts, smart *** comments, etc?
Old Mar 1, 2011 | 05:16 PM
garygnu's Avatar
compcam has a cam quest you could try different cams a see what cam works best.maybe look at a lsr cams for ls engines,they will make a little more power.54-455-11 will make more power then 54-424-11 ,and make it at lower rpms.or contact Patrick-G and get cam better then a shelf cam.
Old Mar 1, 2011 | 09:22 PM
Just checked the 54-455-11 and thats gonna push the limit of my springs (.600 max on springs) at .650-ish lift with the 1.8 rockers. Can anyone running this similar setup with the .600 lift range tell me what I should expect with the xr265hr - not so much powerwise, but more of idle quality, streetability, sound/obnoxiousness, etc.
Old Mar 1, 2011 | 09:40 PM
180ls1's Avatar
that cam will be very mild with your 383. Most guys dont go smaller then a 224/224 on the stock 346. What are your goals for the car in terms of power and drivability?
Old Mar 1, 2011 | 09:59 PM
Driveability first, power second. I baby the car for the most part. I rarely "show off". Every once in a while I'll play on the street with other cars. I cannot race the car at 1/4 mile track anymore because I won't install a cage in this car.
My goal is to add power yes, but without sacrificing driveability and dependability. I have not taken it past 6k rpms since I've owned it, and probably never will. So my ultimate goal is to maximize my power in the rpm range that I use -- not so much in a range of rpms the car will never see.
Old Mar 1, 2011 | 11:55 PM
180ls1's Avatar
Do you have longtube headers or no? that will be a big factor in the cam selection.
Old Mar 2, 2011 | 05:44 AM
Currently there is not longtubes installed. However that is the other thing that is getting installed with the cam.
Old Mar 2, 2011 | 05:59 AM
30th t/a's Avatar
Ive read alot of people like that particular cam who want just what your looking for, great low & mid range but with a little more power up top.
What LSA were you looking at getting? That cam would even be more tame in a 383.
Old Mar 2, 2011 | 06:50 AM
garygnu's Avatar
lift is not as important when making power,duration,LSA,and ICL are.I would get some upgraded stock rockers and get a cam that make power the way you want it.get a custom cam from 1 of the cam guys on this thread.
Old Mar 2, 2011 | 11:04 AM
lobe separation angle is 115. total duration is 265/271 with 212/218 at .050.
I do believe the duration at .050 will be a little broader on my setup with the higher ratio rockers.
I am buying a cam either scenario, so I'd rather find one to best suit the rockers I already have, versus buying different rockers as well.
Old Mar 3, 2011 | 01:58 PM
Any ideas on the tr224 with my setup instead of the xr265hr high lift?
Old Mar 3, 2011 | 05:51 PM
SNLPerformance's Avatar
Give me a call and we can discuss your goals, that comp cam is suited more for a 5.3 in a truck than a 383 in a Camaro imo. Chris, 817-750-2000
Old Mar 3, 2011 | 07:52 PM
180ls1's Avatar
agreed i would call a sponsor and for sure get a bigger cam. the tr224 on 114 will drive like stock in your car with that 383 and a good tune. That cam will also be easy on your valvetrain.
Another cam to consider would be this one.
http://www.engpwrsys.com/index.php?a...ns&productId=8
Old Mar 5, 2011 | 08:57 PM
Thank you guys for all of your input - I'm going to get as much advice from a few sponsors and local hotrod shops before I commit. I realize I'm still being a little conservative, lol.
Old Mar 6, 2011 | 12:34 AM
highgear's Avatar
With that cam, you will have very good idle, great street manners, does not require tuning. It is a LS6 replacement cam. Use with your stock rockers.
I am thinking about getting it also as it will drive better than the cam in my Sig.
Old Mar 6, 2011 | 01:30 AM
ls1 1990 VN's Avatar
mmmm since when does any cam change 'not' need a tune, do you really believe that all cams are exactly identical & all engines read that cam exactly the same.
Old Mar 6, 2011 | 06:52 AM
The major dilemma I'm faced with is do I keep the cam rather small so I can keep my current valve spring and rocker setup, or get a cam the engine more likely deserves but then be forced to change rockers springs etc. If I did it the second way I guess I'm just a little nervous about it being too much for me - as in too obnoxious or annoying to drive as a daily driver. Its getting a tune either way.
Old Mar 6, 2011 | 06:56 AM
And I know lift doesn't dictate the driveability of the cam.
Old Mar 6, 2011 | 08:16 AM
formula c3's Avatar
your stock rockers are fine but I would change push rods + springs no matter what cam you go go luck + don't baby it dive it like you stole it !!! ha ha
Old Mar 6, 2011 | 09:28 AM
I already have the 918 springs (up to .600 lift) and no longer have stock rockers. I have 1.8 ratio rockers.
