trouble with idle
Old Mar 2, 2011 | 03:12 PM
nik1703's Avatar
Default trouble with idle
When I start the car, it will go up to 1500, drop down to almost zero, then go up to 1500 again and idle steady. Sometimes (when its cold), it will go up to 1000, then drop down and die if i dont gas it immediately.
Info: ported heads, hotcam kit, zo6 intake, dyno tuned, full exhaust, M6
what could it be?
Old Mar 2, 2011 | 04:29 PM
RedHotG8's Avatar
Clean the MAF, throttle body and throttle position switch. If that doesn't help the MAF or TP switch could be bad. You could also have a bad O2 sensor.
Old Mar 2, 2011 | 04:36 PM
nik1703's Avatar
sweet. will do.
on my GTI, cleaning the maf consisted of removing it, soaking it in 99% alcohol for 30 minutes, drying it out, and reinstalling it. is that correct?
Old Mar 2, 2011 | 04:53 PM
thunderstruck507's Avatar
also could be poor idle tuning
Old Mar 2, 2011 | 05:18 PM
RedHotG8's Avatar
Just get some MAF cleaner from the auto parts store and spray it inside the MAF to clean it out.
Old Mar 2, 2011 | 11:29 PM
nik1703's Avatar
Will do
I don't believe so because it is only on first start/cold start. after its been running for 30 seconds, idle is solid at 1100.
Old Mar 3, 2011 | 09:37 AM
With a hot cam kit? I would think it would idle perfect at 700-800rpm.
Has it always been this way or just start? There is tuning for cold start and warm idle separate in the PCM. My car did the same thing on cold starts until I got a better tune.
If the idle is set so high on a mild cam car, I wouldn't be so quick to rule out the tune if it's behaved this way the whole time.
But yes, clean the MAF and all throttle body sensors with cleaner from the parts store. Might also check around MAP sensor/intake/all hoses for vacuum leaks.
Old Mar 3, 2011 | 05:01 PM
nik1703's Avatar
Cool, I'll check/do all those things.
Aside from the hotcam kit, it has ported heads, z06 intake and k&n FIPK kit.
Old Mar 3, 2011 | 05:44 PM
02Z28ZO6's Avatar
Start by trying to clean the IAC or Idle Air control valve. It is the top one on the throttle body and these can cause erratic idle if they are dirty or worn out. Mine had some black carbon on it causing a very minor idle issue, cleaned it and the problem was gone.
Old Mar 6, 2011 | 09:04 PM
nik1703's Avatar
Ok. So I cleaned the IAC (sensor on top right of throttle body) with a paper towel (it had a bit of black **** on it) and I also cleaned the MAF with MAF cleaner. Didn't fix the idle issue.
Someone mentioned something about a MAP sensor?
Old Mar 7, 2011 | 09:22 AM
It's on the back of the intake. You can make sure its not leaking by spraying starting fluid or something similar around it while the car is running and see if the idle changes dramatically.
Then clean it like you did the others.
Old Mar 7, 2011 | 01:30 PM
99Bluz28's Avatar
I could definitely be a slight vacuum leak.
Old Mar 10, 2011 | 01:56 PM
nik1703's Avatar
i also noticed the RPM's will jump up 200-400 after i disengage the clutch to shift.
