how do u choose proper headgasket?
Old Mar 7, 2011 | 11:22 PM
txh0tb0i972's Avatar
Default how do u choose proper headgasket?
I was told to choose the head gasket to match bore of cylinder head but I always thought it would be the bore of the block?
Old Mar 8, 2011 | 04:04 AM
vettenuts's Avatar
The larger of the two, i.e., some cylinder head chambers are wider then the bore. My Darts were like that as are my current AFR heads.
Old Mar 8, 2011 | 11:53 AM
hmmm if im going 30 over on a lq9 and im using some 317 casting now he is telling me to use mls gasket for the size of the head chamber bore
Old Mar 8, 2011 | 12:00 PM
SOMbitch's Avatar
Just think about it.... Say your bore has a bigger diameter than the chamber and you match the the HG to the chamber.... then the HG will portrude into the bore.....vice versa is also true so ALWAYS match to the bigger of the two if they are different.....
Old Mar 8, 2011 | 03:27 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
The GM MLS gasket off the 6.0L engines would work, or you can go Cometic 4.03x" bore!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
