Bent Pushrod
Old Feb 16, 2004 | 06:18 PM
LS1 Brent's Avatar
Default Bent Pushrod
I was going through the drive through at Jack N the Box one night and I heard this ticking noise. I reved my engine up just a little bit and the ticking noise increased. My car is an automatic, and I don't ever manually shift it, and I have the stock shift points. Is there a chance I could have a bent pushrod? Or am I just being a hypochondriac? I would like to check for myself if I have one but I'm not the most mechanically inclined person in the world. Is there any other alternative? Your help is greatly appriciated.
-Brent
Old Feb 16, 2004 | 06:26 PM
SLP CARS '98's Avatar
It's possible that you have a bent push rod but not very likely since your car is an automatic. The 6 speeds are known to bend a push rod every now and then. You can take your valve cover off and then remove the rocker arms and pull each push rod out and check to see if any are bent. It looks more intimidating then it really is. It's actually an easy thing to check. Good Luck!
Old Feb 16, 2004 | 06:31 PM
BadAndy's Avatar
The LS1 is kind of a noisey motor to begin with. Sometimes normal sounds can sound weird in a closed in area, like a drive through. If its a Prod, no big deal. See if you can isolate the noise and maybe you'll only have to pull one valve cover
Old Feb 16, 2004 | 07:17 PM
taqwache's Avatar
i just bent one yesterday and thats exactly how it sounded like. the only way to be sure is to remove them. they are not that hard really and the gaskets are usually reusable.
