whos passed CA smog W/ FMS F4 Cam??
You will be fine, i passed with a 224-224 114 and high flowtRandomTech cats and it wasn't even close, burned as clean as a stocker. 226-226 114 still has -2 degrees over lap the rule is -2 to -4 over lap passes easy. Just get a good tune and good cats. People are passing with 228-232 115 which has 0 degrees negative overlap.
